04-10-2019
10:25
19:58
04-10-2019
10:25
19:58
As I was losing weight, I decided to change my goal weight to and even lower number. When I did, it erased my history of when I started and all the pounds I've lost. I want to get that back; does anyone know how to do that? Please help.
04-15-2019
12:23
04:41
04-15-2019
12:23
04:41
Hi, @ljlm61 , unfortunately, when you set a new weight goal the Fitbit program does, as you have noted, begin all over again with a new starting weight and there is no way to recover the previous information.
Hopefully you do have your weight loss badges? These should definitely still be there.
I am really sorry not to have better news for you. It's great to see you in the Fitbit Community, and you might get more help and support by posting in the Manage Weight forums.
04-23-2019 09:17 - edited 04-23-2019 09:19
Of course you can fix that. I just changed my weight-loss goal a couple of weeks ago and I noticed that my weight-loss was going to start from that day forward.....until I went back into my settings and changed my starting weight back to my original starting weight on my original starting day. Everything is there going back nearly 10 months and my new goal weight is reflected.
I can only help you on the Android App. Go to Weight section on your Dashboard, Go up to the gear (in the upper right corner where it says "Edit Weight Goals" if you long press the gear) and click, Click on Start Date and then Starting Weight to reclaim your info.
I don't know if you have the same access on an iPhone.
04-23-2019 15:09 - edited 06-12-2019 14:27
04-23-2019 18:26
04-23-2019 18:26
