03-14-2016 17:10 - last edited on 09-06-2020 20:15 by MatthewFitbit
03-14-2016 17:17
03-14-2016 17:17
@JonnyGs wrote:
I haven't tried it but can you ensure a strong battery for updating if you had the tracker on charge while carrying out an update? Another note, why cant you charge your tracker by plugging it into a computer's USB port? Maybe that's just my computer. 😄
When I installed the firmware v.122 on my tracker, I pluged the tracker into the charger cable before starting the upgrade to make sure the battery didn't die during the upgrade. After the upgrade finished, I left it on the charger until it was fully charged.
I charge mine by plugging the charge cable into a laptop USB port if I'm at the laptop when it needs charging. Or, if I'm not at the laptop, I plug it into the same regular USB charger I use for the cell phone. Either will work.
07-16-2019 11:03
07-16-2019 11:03
I came to check the same: while charging, can it update its firmware?
Hopefully it works like you said, thanks!!
