06-12-2019
02:32
10:58
06-12-2019
02:32
10:58
Hi there,
So recently I've been experiencing some issues with the charge 3 which I've had for about 6 months.
At the top of the screen there seems to be bars which have cut off sections of the display.
As well as this there are vertical faded white lines on the display.
Not only this but the touch screen capabilities don't seem to be responding.
I've updated the firmware recently and have also tried the changing of the clock face as described in other entries with this similar issue is there any other advice that you can give?
Thanks
Josh
Moderator edit: Format
06-12-2019 20:51
06-12-2019 20:51
Hello and welcome to the forums @JoshRStephens
I've notified a moderator about your post and they will be here to offer assistance. Thanks for coming here.
06-13-2019
06:10
08:08
06-13-2019
06:10
08:08
Hi @JoshRStephens! Thank you for the troubleshooting steps, that you have already performed. In this case I suggest that you try restarting your Charge 3: How do I restart my Fitbit device?
In case this situation persists, I kindly ask you to perform a long restart:
Let me know if it worked!
@Odyssey13 thanks for reaching out to us!
06-14-2019 03:56
06-14-2019 03:56
06-22-2020 12:10
06-22-2020 12:10
I've had this happen to me twice now on two different Charge 3. I don't know if it has anything to do with being used in the pool. It's very frustrating! If there isn't a fix for it, I'm getting a different one from a different company.
