08-06-2019
07:23
13:57
08-06-2019
07:23
13:57
When recording a walk with GPS, it tracks "Energy" instead of "Heartrate" since about July 26. What changed? How can I get heartrate back?
08-07-2019 12:53
08-07-2019 12:53
Welcome to the Community Forums @SpencerG, it's a pleasure to give you a hand with this situation.
I appreciate the details that were shared in your post, seems odd that your activity is tracking energy instead of heart rate. To better assist you with this, can you please let me know how are you tracking your walk activity? Are you recording it directly from your device or with MobileRun? How many times since July 26th you experienced this? If possible, can you please send me a screenshot of the Energy information you're seeing? You can refer to this post to do so.
In the meantime I receive your answers, please make sure that your Fitbit app is up to date, same for your Charge 2 device and mobile device operating system.
Keep me posted.
08-07-2019 20:52
08-07-2019 20:52
08-08-2019 00:52
08-08-2019 00:52
I’m facing this problem currently as well. Hope to get a solution as well as it’s affecting my 3rd party app as well, since they need to extract the HR info from the workout.
08-08-2019 01:15
08-08-2019 01:15
Hei
I have had the same problem since my run on July 31th. The exercise does not show the hart rate anymore. The watch still records it and the HR is plotted on the daily HR plot.
@SpencerG wrote:When recording a walk with GPS, it tracks "Energy" instead of "Heartrate" since about July 26. What changed? How can I get heartrate back?
08-08-2019 09:38
08-08-2019 09:38
Hi,
I'm also having the same issue with my Charge 2, I use it with an iPhone 5SE. I use it to record my running and until Jul/25 it was working fine but since my running record of Jul/29 the heart rate is not apeearing in my logs.
When the app/device detect automatically that I'm walking the heart rate appears just as before.
I hope a solution appear soon as I really need to check my running heart rates.
Regards.
08-08-2019 10:36
08-08-2019 10:36
This has been a hot topic on a discussion under “Heart rate data disappeared.” It not only happens on the Charge 2 but most other Fitbit devices. It began the last week of July. All the suggested fixes like logging out, quitting Fitbit app, re-installing the app DO NOT work. Pretty much a run-around from the techies with no solution. Most believe it is a software glitch. Good luck!
