12-05-2018
01:21
14:34
12-05-2018
01:21
14:34
I have had my Charge 3 for about a week.
When I raise and turn my wrist to check the time, the watch face does not display. If I tap the screen with my finger, then it displays.
I have attempted all wrist motions I can think of, and followed suggestions on this forum for how to turn my arm to get the watch face to show, but nothing helps.
It seems to me it was working the first few days, but has stopped in the last two or three days.
Everything else on the watch is working perfectly. I'm hoping this is just some setting I have accidentally changed, or can set back, and not the early symptoms of a malfunctioning device.
12-05-2018 01:46
12-05-2018 01:46
hi there you could of nocked one of the setting off I do this a fair bit my self if you hold the side button in on the c3 you will get a screen pop up saying screen wake and notifications make sure your screen wake is on and not off hope that helps
12-05-2018 01:46
12-05-2018 01:46
12-05-2018 02:40
12-05-2018 02:40
Thank you. That was exactly the problem.
Now I have not only turned the screen wake function back on, but, now I know that holding the side button for an extended time brings up some options settings, which I hadn't noticed before.
12-05-2018 03:19
12-05-2018 03:19
no worries glad it worked for you I have mine turned off to save battery as the flip thing does my head in as you only have to turn you wrist and it pops on lolb
12-05-2018 13:30
12-05-2018 13:30
I was having the same issue and read your solution. THANK YOU!
12-06-2018 10:06
12-06-2018 10:06
Hi, I was also having the same problem... thank you 🙂
12-06-2018 12:46
12-06-2018 12:46
no worries at all glad to help its a easy mistake to make keep knocking my notifications off all the time lol
12-19-2018 15:02
12-19-2018 15:02
THANK YOU!!! This has been driving me crazy all afternoon! must have hit it without noticing and couldn't find anything in the app to fix it. Fitbit developers should really add this option to the APP settings too, as it's super frustrating when you dont know it can only be changed on the device.
12-21-2018 19:40
12-21-2018 19:40
My Fitbit doesn't show a watchface. When the screen lights up it starts at the 'Steps' screen.
Can anybody tell me how to get it to show the watch!?
12-23-2018 19:08
12-23-2018 19:08
WOW! So simple. Love it! Thanks so much.
01-01-2019 01:20
01-01-2019 01:20
I have this problem even with the Screen Wake set to auto. Any other ideas on how to fix?
02-11-2019 14:44
02-11-2019 14:44
Thank you!!!
02-12-2019 20:23
02-12-2019 20:23
Fantastic. Thanks
03-03-2019 20:32
03-03-2019 20:32
Hi there, followed these instructions, turned the "screen wake" and have since restarted the device about 3 times and still nothing changes. Any other suggestions?
03-07-2019 20:31
03-07-2019 20:31
Thanks!
03-12-2019 13:06
03-12-2019 13:06
Helped me! Thank you. 😁
03-25-2019 16:39
03-25-2019 16:39
Wow thanks. This worked for me! I had not found that button. Most grateful.
05-04-2019 00:05
05-04-2019 00:05
Thank you. But you must hold side button down for 1-2 seconds. Then the screen will pop up
05-04-2019 00:07
05-04-2019 00:07
You have to hold down side button for tad bit longer, then the Screen Awake will show.
06-24-2019 23:37
06-24-2019 23:37
Thanks worked a treat.
