12-05-2018
01:21
14:34
12-05-2018
01:21
14:34
I have had my Charge 3 for about a week.
When I raise and turn my wrist to check the time, the watch face does not display. If I tap the screen with my finger, then it displays.
I have attempted all wrist motions I can think of, and followed suggestions on this forum for how to turn my arm to get the watch face to show, but nothing helps.
It seems to me it was working the first few days, but has stopped in the last two or three days.
Everything else on the watch is working perfectly. I'm hoping this is just some setting I have accidentally changed, or can set back, and not the early symptoms of a malfunctioning device.
07-06-2019 08:37
07-06-2019 08:37
thank so much . my watch face was also not turning on when i rotated my wrist. . very happy 🙂
Best Answer07-18-2019 18:56
07-18-2019 18:56
Thanks so much that solved my problem as well I am very grateful for your post
Best Answer08-26-2019 19:41
08-26-2019 19:41
THANK YOU! Goodness I could not get this fixed...and in one second you nailed it! 👍👍👍
Best Answer09-14-2019 20:53
09-14-2019 20:53
OMG this helped sooooooooo much thank you
Best Answer10-15-2019 05:17
10-15-2019 05:17
Thanks, did the trick 👍
Best Answer02-01-2020 11:17
02-01-2020 11:17
I have the Charge 3 Special Edition with Fitbit Pay. If I press and hold the side button it only brings up Fitbit Pay. I don't have a "wake screen" setting
Best Answer02-02-2020 00:52
02-02-2020 00:52
I'm so sorry that this has not helped you.
May I suggest that you Google you particular fitbit to see if there is something to help you out.
That is how I found out about the 'wake screen'.
Best Answer02-02-2020 03:11
02-02-2020 03:11
Best Answer04-30-2020 16:20
04-30-2020 16:20
Can you tell me how to turn it on. I dont see a button to turn the thing on why
Best Answer04-30-2020 19:23
04-30-2020 19:23
Best Answer04-30-2020 21:00
04-30-2020 21:00
On my Fitbit Charge 3 with Fitbit Pay I have to press and hold the side "button", then the lock screen appears. I have to then swipe left to get the screen wake option. It took me forever to figure it out, because everyone said that just pressing the button would bring up the wake option.
Best Answer04-30-2020 23:09
04-30-2020 23:09
When I hid the side button to wake the watch up the tap and pay comes on...can’t activate notifications because of this.. please help!
Best Answer05-01-2020 07:17
05-01-2020 07:17
I had the same issue until I noticed a dot above the lock symbol and realized that I needed to swipe left on the screen to get to the wake screen and notification options.
When I contacted Fitbit via this forum and Twitter I was NEVER told this.
Best Answer06-30-2020 05:11
06-30-2020 05:11
thank you! This solved the issue for me and also why I'm not receiving notifications! X
Best Answer10-24-2020 16:43
10-24-2020 16:43
I tried that, but when I hold the side button I only get the battery level.
Best Answer10-24-2020 16:44
10-24-2020 16:44
I stand corrected. It has the battery level AND the "light bulb" which I now see is the screen wake icon.
Best Answer10-25-2020 03:49
10-25-2020 03:49
Try going into watch faces in the settings and choose one with a clock
Best Answer11-21-2020 08:51
11-21-2020 08:51
I just got a Charge 4, had a charge 2. Which was a lot easier to setup
Best Answer01-05-2021 08:41
01-05-2021 08:41
My Charge 2 will only turn Notifications on or off doing that. 🥴
