07-29-2016
09:09
20:15
07-29-2016
09:09
20:15
07-09-2018
03:42
09:22
SantiR
07-09-2018
03:42
09:22
SantiR
Don’t see my “I quit Fitbit” message written a few weeks ago. Fitbit stopped logging in the midst of my treadmill walk. Tried to buy a new battery. They’re not available!!!! (Who does that?”). Fitbit!
So I un Fitbit. Bye
Moderator Edit: Format
07-09-2018 05:22 - last edited on 01-21-2021 19:39 by LiliyaFitbit
I same problem and it is very frustrating. I have tried every "fix"
suggested and still have the same problem. Fitbit replaced my Alta free of
charge and my new one is better but occasionally it still does not record
my exercise activity.
I wish I had a solution because I did not want to buy such a pricey watch!!
Keep updating and hopefully they will get the bug out!!
07-09-2018 16:20
07-09-2018 16:20
Thanks Rhonda! It started updating when it shouldn't for a week and now it seems like it is working again - for a while!
09:46
05:41
07-10-2018
09:46
05:41
Hello everyone! Thanks for your continuous participation on this thread regarding the weekly exercise goals not updating when using Charge HR.
Any exercise captured in your exercise history counts towards your goal. In this case, there are several ways in which you can track activities with Charge HR:
Any of these option should track your exercise and then it should show under the activity history and therefore update the weekly exercise goal.
If SmartTrack is not working for any reason, please perform a restart on Charge HR. Please use any of the other ways to track exercise for you to not loose your exercise goals.
Hope this helps. Keep me posted! ![]()
Best Answer07-11-2018 10:42
07-11-2018 10:42
Best Answer07-13-2018 07:55
07-13-2018 07:55
For the LOVE OF GOD please stop recommending people manually log their exercise then the Fitbit Alta FAILS to perform. First of all -- this is a failure of your device. FIX IT! Second of all, when you manually log, it subtracts the active minutes and resets the calories burned. UNACCEPTABLE.
07-13-2018 08:56
07-13-2018 08:56
07-13-2018 09:29
07-13-2018 09:29
I agree! Fix it or give us our money back!
Best Answer07-13-2018 09:30
07-13-2018 09:30
nd they h ave the gall to mark this post as "SOLVED." Oh...…..the lies. They burn.
10-17-2018 08:20
10-17-2018 08:20
I have the same problem and it’s more than frustrating.. I’m in a challenge so it adds totals but won’t show my days I worked out.
I cant figure out to do this manually and your answers have not been helpful!!!
Best Answer10-24-2018 11:51
10-24-2018 11:51
Hi - I found this thread today while trying to find out the exact same issue, although i have a FitBit Blaze. Yes, not cheap, and it has never logged the correct number of days per week I work out. I have my goal set at 4 days, last week I exceeded that by 1 and logged 5 days. However, my weekly report only shows that I worked out 1 day. I believe this is because during Spin class, I have to set my tracker to 'Spin' in order to get somewhat close to the steps/cals/mins, etc. However, it's still way off, but that's a different subject.
As others have stated, I also burn more calories and acquire more steps when I do NOT set the tracker to a specific exercise (except Spin). Therefore, it's not advantageous for me to do a manual entry each time I work out. This definitely needs to be fixed. Reading back through all the entries, this is now entering into one full year and still, the only response is to enter exercise manually, and is noted as 'resolved.' It is clearly NOT resolved....
FitBit....I didn't pay $250 for a product that 'kinda' works. This really needs to be fixed across ALL products - quite surprised this has been lingering/open for so long.
C'mon folks - you have a good product, get on the ball and fix the **ahem** software!!
11-28-2018 03:33
11-28-2018 03:33
I was having problems with it logging too. I went to dashboard, weekly exercise, go to tools, goals and switch how many days you want your goal to be. Go out of tools to save it then go back in and change your days back to the goal you want again. That seemed to work with my Blaze
16:56
05:41
11-28-2018
16:56
05:41
@Tina009 I hope you're doing well! Thanks for sharing the workaround that helped you out to get back on track. I'm sure other users will find this useful! Thanks for your contribution on this thread.
Also, take a look at the Discussions Board as you will find a lot of interesting things there. Feel free to post on any thread you want. If you are looking for Fitbit friends to compete with on challenges, check this thread to add some!
See you around!
Best Answer02-23-2019 09:42
02-23-2019 09:42
This still didn’t work for me :(. @SantiR is there anyway Fitbit can go into the system and change it for me?? Obviously nothing is working and I don’t appreciate my tracker not tracking correctly. I don’t want to manually add it because then it adds more steps to my already counted steps which would not be accurate.
Best Answer02-23-2019 11:38
02-23-2019 11:38
Best Answer02-28-2019 19:47 - last edited on 01-21-2021 19:39 by LiliyaFitbit
I have contacted Fitbit several times concerning this, they sent me a new
one and it did the same thing. Obviously they are selling a product that
does not do what they advertise it will do. I suggest you get a refund,
they said I had mine for to long.
Best Answer03-01-2019 04:06
03-01-2019 04:06
Best Answer05-06-2019 23:55
05-06-2019 23:55
my activity minutes was 54 minutes and it updated on the dashboard but not on the weekly exercise. So it did not pull through and i also had to go update it manually so clearly their is a glitch somewhere which has nothing to do with MET
My fitbit 3 watch also shows me when i have reached my 10000 steps but i also notice when going into the app it displays less steps ?? so the 2 are not in sync
Best Answer05-10-2019 10:40
05-10-2019 10:40
I'm having exactly the same problem with my Charge2.
It worked correctly for a year, but just this week, stopped updating weekly exercise on my pentagon. It still logs my active minutes, heart rate increase, and step count, but the pentagon no longer gets filled in.
I tried manually logging the exercise too, but just like the others on here said, that artificially increased my step count for the day, making my other stats inaccurate.
So what is the REAL solution? Come on, Fitbit! Fix this!
Best Answer05-10-2019 13:11
05-10-2019 13:11
