01-07-2016
10:21
20:42
01-07-2016
10:21
20:42
Last night I went to bed at 11:22 PM. My Charge HR's sleep record says I went to bed at 2:30 AM. This doesn't happen every night, but I'd say about 40% of the time. Per suggestions in other posts I restarted the tracker on 1/4/2016 to see if this would cure the problem, which has happened since day 1 in November when I got the tracker. It didn't solve it. My sleep tracking mode is set to normal.
And perhaps related... when my "went to bed" time is reported correctly, I often get split sleep records with gaps between them showing from 7 minutes to an hour and 50 minutes. This happened yesterday, again after I restarted the tracker on 1/4.
Assuming I'm not sleep walking, what should I try next?
01-07-2016 12:11
01-07-2016 12:11
What's your heartrate during those times you're "awake"? I have seen cases where if your heartrate is higher than the norm it reads as awake rather than asleep.
@bithead wrote:Last night I went to bed at 11:22 PM. My Charge HR's sleep record says I went to bed at 2:30 AM. This doesn't happen every night, but I'd say about 40% of the time. Per suggestions in other posts I restarted the tracker on 1/4/2016 to see if this would cure the problem, which has happened since day 1 in November when I got the tracker. It didn't solve it. My sleep tracking mode is set to normal.
01-07-2016
13:54
05:05
JuanJoFitbit
01-07-2016
13:54
05:05
JuanJoFitbit
Thanks for the reply. And while what you say may be true, my question is not about being awake - it's about being in bed - isn't that handled by some triple-axis gyro thingy (my technical term for the day)?
I can certainly see where HR might be used to determine asleep/awake/restless times, but a 3+ hour gap from going to bed to being recognized as being in bed seems a bit extreme.
For anyone following this, I've emailed customer support. I'll try to report back here when I receive a response.
Moderator edit: merged reply
01-14-2016 13:47
01-14-2016 13:47
I don't think it's about being in bed so much as being still. My guess is that you're a bit of a restless sleeper some nights which the tracker will detect. Get restless enough and it will assume you've awoken for a while.
Mike | London, UK
Blaze, Surge, Charge 2, Charge, Flex 2 - iPad Air 2, Nokia Lumia 925 (Deceased), iPhone 6
Best Answer01-14-2016 14:05
01-14-2016 14:05
I do have restless nights sometimes, but not so much that it should take hours before recognizing that I've gone to bed, especially when I've been sleeping during most of that time. In fact, I'll sometimes wake up for a few minutes right around the time the Charge HR thinks I climbed into bed, but again, I've been sleeping for hours already. I would be OK if that time was recorded as "restless" or even "awake", but to not have gone to bed yet is just too inaccurate to be acceptable.
01-14-2016 14:20 - edited 01-14-2016 14:21
It doesn't recognise you've gone to bed until you've been still for an hour. In fact, that's the only way it has of knowing you're in bed (it can't tell you're lying down, for example) so if your levels of restlessness prevents that hour of stillness from occurring then it will think you never dropped off.
I've never tried this, but if you want a better record of sleep, you can put it into exercise mode the moment you climb into bed and turn that off when you get up. It then knows where you are and why and will hopefully give you a better picture of your sleep quality.
Mike | London, UK
01-15-2016 10:47
01-15-2016 10:47
Interesting that it takes an hour to figure it out. Do you know what triggers getting out of bed? And I presume if one does get up in the middle of the night for a few minutes, the one hour countdown starts over again when returning to bed?
01-15-2016 11:54
01-15-2016 11:54
Mike | London, UK
01-15-2016 13:19
01-15-2016 13:19
@MikeF @bithead It takes a pretty substantial amount of movement to take the tracker out of sleep mode- usually a good sold minute or two of walking around should do it.
I drink a lot of water (and the occasional brews), and when I wake up in the middle of the night, my trackers usually reflect the full sleep period with a bit of "awake" splashed in there in order to show me what time I had to relieve myself.
Best Answer01-20-2016 17:49
01-20-2016 17:49
Thanks for the feedback. In my conversatikon with Support, they've confirmed the one hour of non-movement time to recognize being in bed. This looks like it will be a problem for me, as I rarely lay still when I go to bed at night. Also, I guess I can be a bit tumultuous in the middle of the night, as I get frequent reports of being up for long periods before I awaken in the morning. The apparent "sleep walking" isn't bad to deal with as I can correct for it easily in the web interface. But a main reason I bought this device was for the auto sleep tracking - I had a different device before this one that required I manually indicate when going to bed and when getting up, and I was pretty consistent at forgetting to do one or the other. So unfortunately, the Charge HR's sleep tracking is proving to be quite disappointing at this time, and will continue as such until it can more accurately determine when I go to bed.
02-04-2016 17:21
02-04-2016 17:21
@MikeF wrote:I've never tried this, but if you want a better record of sleep, you can put it into exercise mode the moment you climb into bed and turn that off when you get up. It then knows where you are and why and will hopefully give you a better picture of your sleep quality.
FYI, I did give that a shot, but to no avail. Apparently even when manually set to track activity, it still needs a certain activity level before it tracks anything. I tried this twice and both times there was no activity record after getting up the next morning.
Best Answer09-20-2016 07:53
09-20-2016 07:53
09-20-2016 10:28
09-20-2016 10:28
09-24-2016 08:22
09-24-2016 08:22
Best Answer09-25-2017 07:50
09-25-2017 07:50
My Fitbit Alta also started doing this recently. I’ve found if I reset the asleep time manually, it’s accurate. If you back too far it just says awake, so you can basically find your true asleep time by guessing. You can change it again & again if need be 🙂 I too am very annoyed by this. The sleep tracker is one of my favorite features.
Best Answer10-05-2017 04:14
10-05-2017 04:14
Have you considered just making a mental note and adding an hour to that sleep time mentally and to your average sleep time? I think that is something I may need to do because it always says I get one hour less then I usually get.
Best Answer10-05-2017 08:15
10-05-2017 08:15
I'm having the same issue. It's off by at least an hour
Best Answer10-05-2017 08:17
10-05-2017 08:17
I agree. I bought a Charge 2 which is already gone after a few months! I have owned a Fitbit since 2014! I think the Charge 2 is a lemon and don't want another lemon! They will not exchange it for the Aria HR model which is the same price. So I'll purchase a new Charge 2 at a local store and return the lemon Charge 2 and then exchange it for the Aria with the heart rate. I bought this on line, but this option will get me what I want! In the future I would purchase another product as I know as I now know how crappy Fitbit customer service is!
01-11-2018 04:45
01-11-2018 04:45
I'm having the same problem. Contacted customer support & we reset my alta hr. Still hours late with my sleep start time. It's getting aggravating. It's brand new!
Best Answer04-01-2019 04:17
04-01-2019 04:17
My Fitbit has been doing the exact same thing for several weeks. I’ve been wearing one for ten years and feel like throwing it away.
