10-08-2018
03:09
15:47
10-08-2018
03:09
15:47
Hi,Question is when I get the special edition Fitbit charge 3 UK. Which banks ect accept it?
Moderator Edit: Updated Subject for Clarity
12-16-2019 22:02
12-16-2019 22:02
Best Answer12-16-2019 22:40
12-16-2019 22:40
Best Answer12-16-2019 22:44 - edited 12-16-2019 22:45
It could be you have just set it up. When your card arrives it will definitely work. I have the free card and have used it via Fitpay no problem.
Best Answer12-16-2019 23:01
12-16-2019 23:01
Best Answer12-16-2019 23:41
12-16-2019 23:41
Best Answer12-17-2019 00:17
12-17-2019 00:17
Best Answer12-17-2019 00:47
12-17-2019 00:47
Best Answer12-17-2019 00:53
12-17-2019 00:53
Harry hope you did realise you don’t need to use the £14.xx per month charge? Unless you like the extra benefits with the paid account.
if you want the free card change it to the free blue card or contact CS to change it for you. 😊
Best Answer12-17-2019 01:00
12-17-2019 01:00
You can if you get a free Curve card. Don’t go for the £14.xx per month just flick left till you get the free card.
Give it a go Its free to join and controlled by the Curve app on your mobile. Use this code and get £5.00 free money and a free card https://www.curve.app/join#N25PWJPN
Best Answer12-17-2019 01:41
12-17-2019 01:41
https://www.moneysavingexpert.com/news/2018/01/new-curve-card-lets-you-connect-your-existing-cards-a...
check out money saving expert for further information.
Best Answer12-17-2019 01:51
12-17-2019 01:51
Hi frank, yes I chose the blue free card it’s on it’s way I used the link you sent!
I did try linking it to my Fitbit ionic but won’t let me at the moment says not compatible but think it will be ok when my blue curve card arrives !
Thank you again for telling me about the curve app & card excellent idea for Fitbit pay.
Harry
Best Answer12-17-2019 02:47 - edited 12-17-2019 03:47
In answer to Colpaco check out money saving expert for further information.
I always in life put things on an imaginary set of scales. Curve has many good points even before being able to use Fitpay. The only down side for me was the Section 75 credit card protection but in the event of a big spend I would use the main credit card for payment so sorted.
On the point of the exchange rate, that was another down side BUT to overcome this I use a Revolute card. Use this code to check it out https://www.revolut.com/referral/frankhl3d
Revolute can then be used via your Curve card to make payment abroad once you have put money onto the card which is dead easy. I used it in Poland and got an excellent exchange rate (check out the rules) and was so easy to use. I now only cary two cards. Curve and Revolute if abroad to get cash with no charges.
In the event I lose my card holder I can put a stop on just two cards. Plus I get a text on each withdraw from my card.
Best Answer12-17-2019 04:52
12-17-2019 04:52
Best Answer01-14-2020 09:30
01-14-2020 09:30
I've got to point out that Fitbit has to start somewhere so the main banks wont be there initially. Also it wasnt that awesome of you to do zero research before purchase.
Best Answer01-14-2020 09:52
01-14-2020 09:52
Hi Wendy
did you try the free Curve card?
Best Answer01-14-2020 09:57
01-14-2020 09:57
Hi hope I don’t have the wrong end of the stick but you can use all the main banks with Fitpay just get the free Curve card. Scroll for the link and get a free card and £5.00 when you start using it
Best Answer01-14-2020 10:48
01-14-2020 10:48
I've just dumped my fitbit, after only one year and over 200 quid spent I had so many problems with it and now the screen has given up.....so I just went out and purchased a samsung active 2....set up no problem....payments with my bank card.....no problem.....issue resolved .....sorry but bye bye Fitbit you've fell behind in the game and technology has left you behind
Best Answer01-15-2020 23:59
01-15-2020 23:59
Bit late now BUT did you know you could have phoned tech support and they would have sent you a replacement Fitbit The Samsung 2 looks like a good bit of kit BUT only last 1 to 2 days and can't share the data with Apple Health if you use an iPhone. If you have a Samsung it looks good apart from the battery life, a bit like the Apple watch.
On the replacement the first Fitbit 3 they sent out was not working so had to wait for the second one which is working fine.
Best Answer01-16-2020 01:38 - last edited on 02-10-2020 18:06 by LiliyaFitbit
no because it's out of warranty and I've had SO many replacements and battling with them previously that I can't deal with the headache of it all, plus they've made themselves very difficult to contact. Luckily I have nothing to do with apple have a samsung phone, so I shall see how long this one lasts
Moderator edit: format
Best Answer02-09-2020 03:34
02-09-2020 03:34
I had issues with the lack of bank support as well. I ended up getting a Starling card. It's handy for those rare times I use the watch to pay for items. Also you can just use the Starling card as a top-up card. You also get monthly interest on the amount you have in the account.
