06-21-2017
16:18
09:49
06-21-2017
16:18
09:49
Just purchased a Fitbit charge 2 took it off this evening and the back where batter is. Has 2 little green lights that are flashing. Not sure if this is normal or not, did it notice them before. Thanks
06-21-2017 16:22 - edited 06-21-2017 16:28
It's normal, those are the heart rate sensors.
06-22-2017
01:45
09:57
AlvaroFitbit
06-22-2017
01:45
09:57
AlvaroFitbit
Thank you now I feel silly but now I know. Thanks for your response
Sent from my iPhone
06-27-2017
10:00
07:08
06-27-2017
10:00
07:08
@Micheletv123 I hope you're doing well! Happy to see that @Amy1015 was able to explain what the lights on the back of your tracker are. Don't feel bad as this is a really good question for any user so if you would like to know more about your new Charge 2 you can check it's manual here.
Let me know how it goes!
Best Answer08-10-2018 20:55
08-10-2018 20:55
So what does it mean when you have 2 green lights flashing after your fitbit dies on you and you plug it in to charge, but nothing happens? No charging has happened since I plugged it in over 6 hours ago, but the two green lights are still flashing. Also keep in mind that my last sync was done on July 19th because neither my phone nor my iPad can see the fitbit to sync it?
08-27-2018
12:45
07:07
08-27-2018
12:45
07:07
@Jessmp213 Welcome! It's nice to have you on board! Sorry to hear that your tracker isn't working. The green lights are the part of the heart rate sensor. If the tracker shows these lights it means that it is charging. If you don't see anything on the screen it could be an issue with the display itself. Try restarting your tracker by doing the following:
Plug the charging cable to your computer or UL certified wall adapter.
Align the contacts of the tracker with the charging cable and plug it in making sure it snaps securely.
Your tracker should start charging.
Press the button for 10 to 12 seconds.
You should see your tracker's firmware version and you can now unplug your tracker.
Keep me posted!
09-23-2018 09:16
09-23-2018 09:16
I have the exact same issue with the green lights flashing non-stop and no response on the display. It will not charge and my phone app does not see it to sync. I've cleaned the contacts and I've tried to restart it and no response to anything.
10-14-2018
08:41
07:07
10-14-2018
08:41
07:07
@tk1ders Welcome to the Fitbit Community! It's great to have you here! Sorry to hear about your Charge 2 not working and for the delay in my reply. Thank you for following the suggestions in this thread. Since none have worked please let our Support team know so they can further assist you. I noticed that you already have a ticket with them so I wanted to know if they were able to help you?
I look forward to your reply!
Best Answer10-15-2018 09:42
10-15-2018 09:42
Thank you for your reply...I was helped but it did not solve my problems with my Charge 2 which is/was only 1 yr and 4 months in use by me. That said, they provided me with a 25% discount for a new one but that still costs $100 for something that shouldn't have failed so soon.
Best Answer11-18-2018 20:15
11-18-2018 20:15
Does the green flashing lights on the back of the Fitbit change 2 give off radiation?
06:39
07:07
11-26-2018
06:39
07:07
@ChloeYas It's great to see that you've visited the Fitbit Community! Thank you for your inquiry. Fitbit trackers operate at such low RF power levels that they are exempt from the evaluation used for other devices (like cell phones). This means our trackers are in a completely separate category, and emit significantly less energy than phones or other RF devices. I know that it's easy to worry about things like RF exposure, but hopefully it helps to hear that our products operate far below FCC compliance levels, and are considered to be completely safe.
Best Answer04-14-2019 03:40
04-14-2019 03:40
I got my fitbit charge 2 for Christmas and have just tried to install it. App won't connect, fitbit dead except for two green lights on back. Charged for 24 hours now.
Best Answer06-08-2019 11:54
06-08-2019 11:54
How do I know it's charging?
Best Answer09-01-2019 07:50
09-01-2019 07:50
There are 2 blinking lights that are touching your skin so its right that they are the heart rate sensors. But recently, after updating to the new syatem released by Fitbit, my device now flashes two green lights like a hazard light (in cars) and system has become slow. What does this mean? battery also dies out after half a day with or without activities
Best Answer09-02-2019 09:03
09-02-2019 09:03
I have the same problem since yesterday when it automatically updated. It went flat after 2 hours
06-16-2021 05:39
06-16-2021 05:39
What if one of the lights is no longer on?
Best Answer03-09-2023 22:24
03-09-2023 22:24
Really because I put it in a dark room and it said that my heart rate was 70 I wasn't even wearing it. I'm sorry if I sound rude I'm just curious about it
Best Answer03-09-2023 22:26
03-09-2023 22:26
It's the charg5
