11-09-2020
01:44
16:17
11-09-2020
01:44
16:17
Hi. What are the best settings for GPS? I had mine set on phone today and had my phone with me. I set the watch to record my walk. I walked over 5km but the Fitbit only recorded 2.88km and provided no map. Any suggestions / help?
11-09-2020 06:38
11-09-2020 06:38
Hi, @coynies , welcome to the community, as a rule of thumb no map = no GPS, for some reason your charge 4 did not link to your mobile phone for your walk. I walk for about 2.5 hours a day and use my phone GPS with reliable results. Allow me to describe my routine?
The charge 4 GPS settings are phone GPS, GLONASS on, low power GPS off. These last two only affect the built-in GPS allowing slightly more accurate fixes in higher Latitudes and quicker "connection". You must ensure your phone Bluetooth is on. On starting my walk I go to exercises, "walk" and touch "start", wait for the dancing GPS arrow to indicate "connected" then touch the "play" arrow after which you can touch the screen and choose the display you want. On completing your walk touch the side button twice and touch "finish" when you will see a time indicating how long you walked for. Sync your phone app and details will appear. How do I use GPS on my Fitbit device? provides much more detail.
I hope this is helpful, let me know how you get on.
Cheers
Gr4ndp4 | UK
11-09-2020 07:11
11-09-2020 07:11
I had the same issue this weekend, I went on a 20mile bike ride but my fitbit only recorded about 12 miles.... the first mile was a bust because the GPS wasn't functining well and kept losing connection, prompting me to change my settings (Use Built-In, GLONAS on and Low Power Off), and then I got the correct map but inaccurate distance. Not sure how to improve the GPS tracking so I can get the correct distance logged.
11-09-2020 10:33
11-09-2020 10:33
Hi, @Michsam23 welcome, I suggest you follow my advice in the earlier post here.
Cheers
Gr4ndp4 | UK
11-27-2020 11:43 - edited 11-27-2020 11:43
Hi, I mentioned in my post that I already did that and am still getting inaccurate data.
04-08-2021 23:30
04-08-2021 23:30
Best setting! By far! Thank you so much 🙏🏾
10-07-2022 08:02
10-07-2022 08:02
Would I use the same settings for higher latitudes? What is considered higher? I am at 47°N....
