08-22-2017
09:49
20:15
08-22-2017
09:49
20:15
I went swimming wearing my fitbit HR thinking it was waterproof. Then I realised it wasn't when the battery died on me. I've tried letting it go completely flat and for a moment I thought it was ok, then it died again. It just shows a thin bar across the screen which is half full. The page on my phone tells me my battery is dead. Any advice?
08-22-2017 10:37
08-22-2017 10:37
@ange1 be sure to get out any excess moisture from your Fitbit by putting it in a dry bowl or rice for a day or two. Then clean all the contacts points and charge the device, plus do a restart. This is about all you can do.
Try that and let us know what happens.
08-23-2017 01:08
08-23-2017 01:08
08-24-2017 13:19
08-24-2017 13:19
Hey @ange1 and @Odyssey13, hope you are doing great and enjoying some healthy activities.
@Odyssey13 thank you for the awesome instructions provided here, I'd like to add the restart steps to help @ange1 to get the Charge HR back:
Once the restart process is done, if you still have the slim bar on the tracker's display, please try the steps I posted here.
Let me know if you have questions.
What's for breakfast?Check others recipes and share yours!
08-29-2017 01:20
08-29-2017 01:20
08-30-2017 08:53 - edited 08-30-2017 08:54
It's nice to see you again my friend @ange1. I want to thank you for trying all the suggestions from this thread, since any of them worked, I've created a support case, please check the inbox of the email address you used to create the Community account since our support team is going to contact you to give you more information.
I'll be around.
07-16-2019 08:53
07-16-2019 08:53
Hi!So my Fitbit has been doing the same thing and I even put it in rice and tried to reset it MANY TIMES but it won’t work!I have an HR too, can anyone help me out🥶🥶
07-16-2019 09:21
07-16-2019 09:21
Hi @salhulluo
Sometimes it takes 48 hours or so in rice before charging and restarting it. There is also the chance that your Charge HR has died. With all the sales going on, you might want to think about a new Fitbit.Try the rice again, clean all connections and then charge and restart it. Let us know how things go for you.
