08-08-2020
13:12
16:17
08-08-2020
13:12
16:17
The Help articles indicate that the Charge 4 has the following types of GPS: dynamic; built-in; and phone GPS. What is the difference between dynamic GPS and phone GPS?
08-08-2020 16:44
08-08-2020 16:44
From How do I use GPS on my Fitbit device?
GPS Mode |
Note: If the GPS signal is lost during the exercise, Charge 4 doesn't switch to a different GPS type. |
GLONASS | For exercises with built-in GPS, this setting can shorten the time it takes for Charge 4 to find a GPS signal and enhance GPS performance. Note: Turning on this option can reduce battery life on your tracker. |
Low Power Mode | For exercises with built-in GPS that last more than an hour, this setting can preserve battery life on Charge 4. To enhance built-in GPS performance, turn off the Low Power Mode option. Note: Turning off this option can reduce battery life on your tracker. |
08-08-2020 16:44
08-08-2020 16:44
GPS Mode |
08-08-2020 17:00
08-09-2020 06:53
08-09-2020 06:53
Welcome to the Community, @Norfish1 and @JohnnyRow, thanks for the input.
I was able to see here that our friend @JohnnyRow provided information about your GPS inquiry. Was this the answer you were looking for? If it was, I recommend marking the answer given as the best answer. By doing this, other users with the same inquiry will be able to find a faster response.
Now, if your inquiry/issue wasn’t resolved, let me know and I will be glad to help you out.
09-11-2022 00:45
09-11-2022 00:45
Excellent and straightforward answer that could actually understand!
