What is the heart with two dots on Charge 2?
ANSWERED
1 BEST ANSWER
Accepted Solutions
@Sharon5678   Here is a link to the Alta HR manual.  P 19-20 explains the heart rate dots.
Laurie | Maryland
11 REPLIES 11
Your Heart Rate at that point in time.
What does heart symbol with 2 dots?
@KaymagnessPlease read the message above yours
Community Council Member
Wendy | CA | Moto G6 Android
It means it is having problems reading your heart rate, i hope your still alive, just kidding.
It might be the tracker is to lose, or to close to the wrist and over a bone.
Please see this help doc http://help.fitbit.com/articles/en_US/Help_article/1582/?q=Heart&l=en_US&fs=Search&pn=1
I'm sorry but all these people are wrong. The heart with the 2 dots means you are in the fat burning zone. There are also some other symbols as well for the different zones.
I also wish to ask fitbit manufacturers to explain what a heart symbol in the dashboard with a number of dots in Both of its sides signify. The tracker to be able to warn a person about his heart condition.
I am asking about a number of dots not above or below but on both sides left and right of the heart symbol.
@Tapasdutt Welcome to the Fitbit Community! I hope you're doing well! Thank you for your inquiry. This should explain the heart rate symbol you are seeing:
PEAK ZONE
Peak zone, which means your heart rate is greater than 85% of maximum, is the high-intensity exercise zone. The peak zone is for short intense sessions that improve performance and speed.
User-added image
CARDIO ZONE
Cardio zone, which means your heart rate is 70 to 84% of maximum, is the medium-to-high intensity exercise zone. In this zone, you're pushing yourself but not straining. For most people, this is the exercise zone to target.
User-added image
FAT BURN ZONE
Fat burn zone, which means your heart rate is 50 to 69% of maximum, is the low-to-medium intensity exercise zone and may be a good place to start for those new to exercise. It’s called the fat burn zone because a higher percentage of calories are burned from fat, but the total calorie burn rate is lower.
User-added image
OUT OF ZONE
When you’re out of zone, which means your heart rate is below 50% of maximum, your heart rate may still be elevated but not enough to be considered exercise.
User-added image
Let me know how it goes!
Alvaro | Community Moderator
I’m not seeing any pictures with your explanation.  On my AltaHR there is a heart symbol with two dots over it, what does that mean.  Then there’s a heart symbol at times that has a dot above and a dot below, what is that?
Welcome to the Fitbit Community, @Sharon5678. Thank you for sharing your heart rate inquiries.
Images were removed but you can check help article: How do I track heart rate with my Fitbit device?
I hope this information helps.
Laurie | Maryland
