06-17-2024
08:57
08:33
06-17-2024
08:57
08:33
What's the lowest heartbeat rate the Charge 2 can pick up? A Google search says the Charge 3 can get 30 bpm, but I found nothing on the Charge 2. The lowest I've SEEN it pick up is 42 bpm, but before that the display wasn't showing a reading. (I know that this isn't an error because I have a naturally low heart beat, and when it drops this low I get dizzy and feel like puking.)
06-17-2024 11:27
06-17-2024 11:27
Hello @StaceyMelissa
I moved your post from the Mind & Body forum to the Charge product help forum where you're more likely to get a reply.
Best Answer06-18-2024 10:08
06-18-2024 10:08
Hi @StaceyMelissa Fitbit didn't give accuracy ranges for all of its models. From time to time, Fitbit's Help article gave the range for a device, like you found for the Charge 3, but not always. I don't think the Charge 3 numbers apply to the Charge 2. I used both of them and they have different heart rate monitors.
Laurie | Maryland
Best Answer06-26-2024 19:00
06-26-2024 19:00
I have a Charge 4 and I will get reading down to 36. I have a low 40s RHR. I use to have a charge 3 and it would also read in the mid 30s. If you think your device is off. Compare it when you get a heart rate reading from a blood pressure device or at the doctor's office.
