06-01-2020
23:24
16:20
06-01-2020
23:24
16:20
I tried to turn off all notifications on the charge 4. This bloody disco ball appearing accompanied by vibrations during my workouts does my nut in. How do I get rid of this?
06-01-2020 23:56
06-01-2020 23:56
We each have a primary daily goal. By default it is 10,000 steps and when we hit our primary goal we get a "celebration" on the fitbit.
I'm not sure we can can turn it off but we can change it - either to another metric such as distance, or to a different value. It it's of no interest to you you could just change it to a value you will never reach. Instructions are in the following help file:
06-02-2020 00:30 - edited 06-02-2020 01:21
Thank you so much, it was driving me around the bend. It's rather well hidden innit?
Android Fitbit app, upper lefthand corner, activity.
Best Answer01-07-2022 21:22
01-07-2022 21:22
This approach affects more than just the unwanted Fitbit notifications, since progress towards your goals will be unmeasurable (since you had to make the goals physically impossible due to lack of software features)
04:27
11:27
01-08-2022
04:27
11:27
Hello @rkeene and welcome to the Community forum. I can see from your profile that you are a new user. Can you give a few more details about any issues you are having with your Charge 4 and notifications?
I want to add that the changes made by the OP were a little over the top. You set one main goal. You get the vibration with your main goal. The OP didn't need to change everything.
Laurie | Maryland
01-08-2022 07:12
01-08-2022 07:12
Thanks for the info, I appreciate it and it is useful. It's still obnoxious that I can't measure progress towards my main goal (which remains set to basically infinity) just to avoid getting spurious notifications that cannot be disabled.
