06-28-2021
		10:00
		15:45
			WilsonFitbit
		06-28-2021
		10:00
		15:45
			WilsonFitbit
 Best Answer07-02-2021 15:26
07-02-2021 15:26
OK ... BREAK THROUGH! Turns out that even though the Display shows "25 Meter" pool, it's calculating in YARDS! I guess it Knows That from measuring my lap distances? So 73 laps times 25 meters is 1,825 Meters, but it IS translating that into Yards. Whew ... 🙂
 Best Answer06-28-2021 10:24
                              06-28-2021 10:24
It might help if we knew which tracker you are using.
06-28-2021 11:13
06-28-2021 11:20
                              06-28-2021 11:20
After you select 'Swim' in the Exercise App, swipe up (scroll down) to see other settings specific to swim. One is Pool Length where you can change the number and the units (meters or yards).
06-28-2021 15:44
 Community Moderators ensure that conversations are friendly, factual, and on-topic. We're here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
                              06-28-2021 15:44
Hello @makofoto. Welcome to the community forums! @JohnnyRow Nice to see you around and thanks for your great input!
@makofoto Thank you very much for the detailed information and for the picture. Adding to JohnnyRow's post, I'd like to let you know that if you have additional questions or inquiries about how to track swims using your Charge 3, you can visit the following help article:
How do I track my swims with my Fitbit device?
On a side note, I've moved your post to the Other Charge Trackers board to keep our forums organized.
Hope this helps.
 Best Answer06-29-2021 15:53
06-29-2021 15:53
As you can see from this screen grab ... that is NOT an option on my Charge 3.  😞
 Best Answer06-29-2021 16:55
                              06-29-2021 16:55
It appears you are not using the Exercise App on your tracker, but instead you are relying on your swim being auto-recognized. What I said above would apply if you use the Exercise App on your Charge 3. From clock face, scroll right to 'Exercise', then scroll left or right to 'Swim'. If Swim is not one of the options, see How do I track my workouts with my Fitbit device?
If you prefer to stay with auto-recognition, try setting the Units. On phone app:
Profile Pic > App Settings > Units > Length
 Best Answer06-29-2021 17:24
06-29-2021 17:24
 Best Answer06-29-2021 17:58 - edited 06-29-2021 17:58
I did not say you could not correct the pool length. I suggested changing the units to see if that works.
06-29-2021 19:01
06-29-2021 19:01
 Best Answer06-29-2021 19:43
                              06-29-2021 19:43
Have you tried changing the units in the Exercise App for Swim as I originally suggested?
07-02-2021 15:18
07-02-2021 15:18
Perhaps 50 times over the last two years ... I've checked to make sure the Swim Unit Length is set to YARDS. I don't know why they make the Default Pool Length 25 METERS ... IN THE USA?
07-02-2021 15:26
