09-26-2018
21:25
18:22
09-26-2018
21:25
18:22
I'm from Chennai, where can I service my fitbit watch
09-27-2018
04:53
09:12
AlvaroFitbit
09-27-2018
04:53
09:12
AlvaroFitbit
Welcome to the forums!
They can not be repaired. Please contact support
http://help.fitbit.com/?l=en_US&cu=1&fs=ContactUs
Check out the discussions boards! A lot going on and I'm sure you have some contributions as well!
Hope to see you around!
Wendy | CA | Moto G6 Android
09-27-2018 09:11 - edited 09-27-2018 09:12
@IndumathiMano It's great to see that you've visited the Fitbit Community! I will gladly assist you with this inquiry. As @WendyB said there aren't repair centers but I would like to know what it is happening with your Charge 2. Is it having a physical problem or is it something else? Have you tried any troubleshoots? Still you can let our Support team know about the issue as previously described but if it is an issue that can be troubleshooted with simple instructions then we will be more than happy to help you. Also check the warranty for more information.
I look forward to your reply!
Best Answer09-27-2018 09:21
09-27-2018 09:21
Best Answer12-05-2019 17:01
12-05-2019 17:01
Hi Alvaro,
I'm using fit bit versa , have a battery issue.its drain drastically with in half a day battery comes under 20 % where can i service in Chennai and also please send a link to buy battery for fit bit versa.
12-30-2019 05:30
12-30-2019 05:30
My Fitbit versa suddenly shows a very dim display even when brightness is set at max. Battery got fully discharged in half a day from 99% charge. Where can this be repaired in Chennai, India?
Best Answer10-27-2020 02:56
10-27-2020 02:56
Fitbit service is very bad in India. I have bought the watch and it is the 3rd watch which is waste as there is no service center. I have stopped feeling Fitbit is worth it in India as they don't even care to even replace the watch which is not working after a year timeframe quoting the policies.
Not sure the hardware was done intentionally to go waste after a year.
Better go for cheaper watches which is better than fitbit
10-27-2020 02:57
10-27-2020 02:57
Fitibit don't have any service in india. Just we have to throw it in dustbin as they will not also care to replace it.
10-27-2020 03:27
10-27-2020 03:27
08-01-2021 02:50
08-01-2021 02:50
Exactly it was frustrating, would have got for 2k ,3k Chinese smart watches those are many time better than crappy fitbit. worst consumer response.
Best Answer08-09-2022 19:44
08-09-2022 19:44
Same here
Best Answer12-29-2022 02:05
12-29-2022 02:05
No Service centre & Support centres in Chennai. So, it's not useful...
