07-18-2021
00:12
06:45
WilsonFitbit
07-18-2021
00:12
06:45
WilsonFitbit
I’m on ios and can no longer find silent alarms tab on my phone. I know they’re on the watch but I keep getting an alarm come on early morning which says it’s off. I want to be able to check/ sort this from my phone.
Where is this please?
Moderator edit: subject for clarity/format
07-18-2021 09:07
07-18-2021 09:07
Hi @Bex1820 the alarms are now found on the actual device and no longer on the app. Try removing the alarm again and then sync. The alarm has a little slider that turns it off and on. Might be a slight move of the finger turned it back on. Let us know what happens.
07-19-2021 06:52
07-19-2021 06:52
Hello @Bex1820. Welcome to the community forums! @Odyssey13 Nice to see you around and thanks for your great input!
Adding to the post above, I also recommend visiting the following help article for additional information about alarms and to get tips about how to remove them: How do I manage alarms on my Fitbit device?
Hope this helps.
