01-18-2017
10:06
10:13
01-18-2017
10:06
10:13
When using a stair master- which option in the exercise category is the best to choose to get the most accurate results?
01-18-2017 11:01
01-18-2017 11:01
It is hard to say, @EAPesco, but I would guess WORKOUT would be the best option since your arms aren't moving during that time and it can't count steps. The Workout mode will monitor the activity, heart rate, and calories burned.
01-24-2017 06:12
01-24-2017 06:12
@EAPesco It's great to have you here! You could add the Stair Climber workout on your tracker by going to it's settings under Workout Shortcuts and try this option (remember to sync after making the changes so it reflects on the tracker). I think is the most closer workout to your Stair Climber activity.
Let me know how it goes!
03-06-2017 14:37
03-06-2017 14:37
Thank you!!! I job the stairs manually at the YMCA every day, but really would like to use the stair master and didn't know how until now. I've changed my settings, done a sync and will test this out tomorrow. With any luck, it will work for me ... because the stairs I use are also the stairs to a doctor office, so I end up marching in place a lot to keep my heart rate up between flights. 😄 Never have I been so excited to do stairs until now!
03-07-2017 06:19
03-07-2017 06:19
@KimBanks Thanks for joining us! Glad I could help. I just want to clarify that your tracker will count floors for every 10 ft it detects you have climbed using it's altimeter so it won't count floors on your stair-climber. The mode I mentioned on my previous post helps record the activity and provide a better calorie calculation because you are telling the tracker what exactly you are doing during that period.
Keep me posted!
09-14-2017 23:42
09-14-2017 23:42
Will this setting count steps while on the stair master?
09-16-2017 07:51
09-16-2017 07:51
A warm welcome to the Fitbit Community @Vabrav18! Yes, it will unless you hold onto the side rails.
01-21-2018 07:38
01-21-2018 07:38
which fitbit do you have? I have the HR Charge 2 and im having this same issue.
01-21-2018 08:15
01-21-2018 08:15
01-21-2018 09:08
01-21-2018 09:08
@Vabrav18 then why not slow down, holding on will reduce the calories burnt by up to 40% compared to not holding on.
Holding on has also been proven to cause the body to unlearn how to balance, making it more dangerous when on a free run outside.
01-24-2019 05:58
01-24-2019 05:58
Can this be done with the Fitbit Blaze? I can't seem to figure out the exercise "shortcuts", I don't see that anywhere.
01-24-2019 10:15
01-24-2019 10:15
@hwing let's go to Fitbits interactive and searchable help docs, link to help found bestow.
How do I track my workouts with my Fitbit device?
01-24-2019 10:19
01-24-2019 10:19
@hwing let's go to Fitbits interactive and searchable help docs, link to help found below. Your tracker has the option to add the mode called Stair master.
08-02-2019 15:56
08-02-2019 15:56
Nope it's not accurate by alot of calories stairmaster saidbid burned 304 fit bit said 86 that's a big difference
08-02-2019 16:21
08-02-2019 16:21
Yes that is a big difference, but it doesn't say which if any is correct. Did you setup gender, age, weight, etc correctly?
Just a note, most exercise equipment has been proven to add "feel good" calories.
09-14-2019 13:32
09-14-2019 13:32
I have a Surge and Stairclimber is not one of the options.
01-01-2020 05:37
01-01-2020 05:37
Thank you for this information. I didn't know this. I will now modify my stair climbing accordingly.
01-01-2020 05:58 - edited 01-01-2020 05:59
Yes we know @snoopdon that is why it has been suggested to use the mode called workout. Then after a sync, the user may want to tap edit and classify as "Stair Climber"
08-05-2020 07:47
08-05-2020 07:47
I want to buy fitness wear model Fitbit Pro3. I do not find a specific confirmation in specs that it can track stair climbing and display the number of steps and the elevation climbed. And calculate the calories, spent correctly. Can someone confirm please
