Which number is accurate regarding how much battery life I have left in my C4?
How do I know how much battery life I have right now on my Charge 4? The C4 & app initially read 41%, the C4 after I plug it in then reads 24% as now does the app.  What’s going on? This is a significant drop. How much battery life is actually left in the C4 right now? Which number is accurate? Thanks.
3 REPLIES 3
@NewSuttonGirl , Nice to see you here. Thank you for your message.
It seems that for the last synchronization, there were a lot of data that needed to be synced. (eg. GPS maps, several activities, etc)
This could have used the battery before charging.
Usually when synced, the Charge 4 and the app, will show you the current battery status.
And depending on usage it may vary.
Hope this helps you further.
See you around.
See you around.
Thanks for responding to my question, Juan.  I don’t understand your response though.  I didn’t sync the C4 just before I plugged it in to be charged.  I synched it after my most recent walk which was 2 hours prior.
