10-07-2018
08:25
15:47
10-07-2018
08:25
15:47
Just got this and after doing the firmware update a white line appeared across the screen. I have tried restarting it, plug in the charger and hold for 8 seconds till face shows. This didn't fix it. Also changed the clock face.
At this point, I believe its dead pixels.
Here are some images of it
https://drive.google.com/drive/folders/14w6VTL5EDAws9yjU3DUKIiLsj2jpgoss?usp=sharing
I hope someone can help me if not I will simply return it for a replacement.
Edit
Thought I would update this to let anyone interested know. I have replaced it at the store I bought it from and the new one is all good.
moderator edit: title for clarity
10-07-2018 09:07
10-07-2018 09:07
I would say return it for a replacement.
10-07-2018 09:07
10-07-2018 09:07
10-07-2018 09:29
10-07-2018 09:29
I believe that's the progress bar for the update... when it's done it should go away
10-07-2018 09:34 - edited 10-07-2018 09:35
@Cyric wrote:I believe that's the progress bar for the update... when it's done it should go away
I don't think it is. You cant use it when its updating and the background is normally blank. This is the second one I have set up. My dads and my own. But thank you for the reply.
10-07-2018 12:03
10-07-2018 12:03
The white line is supposed to be for the firmware update. Mine hung during the firmware update and it sounds like that's what yours has done. I had to factory reset and then turn off connections to all other bluetooth devices in proximity. I also had to update my app. Eventually, it updated, but I don't appear to be able to sync to my phone.
10-09-2018 07:37
10-09-2018 07:37
how did you do a factory reset on the charge 3?
10-09-2018 14:11
10-09-2018 14:11
Plug the device in to charge. Push down on the "haptic feedback" panel on the left side of the watch (where the button was on the HR2) for about 8 seconds. You'll get a reboot screen.
10-09-2018 14:22
10-09-2018 14:22
Progress bar for Firmware update. Just got my charge 3 and it needed an update. Once the update was done. The bar was gone.
01-10-2019 02:38
01-10-2019 02:38
Dear all,
ABNORMAL WHITE HORIZONTAL LINE ACROSS THE SCREEN
Even it looks like this issue has been risen by many Fitbit Charge 3 users recently, and many opinions have been expressed, there is no official answer from Fitbit itself.
The official approach is to write an email to support center, which will give you an automatic answer that - them being so busy - you'll get your answer in "2 or more days".
And this for a malfunction appeared hundreds of times for top-of-the-line product just unboxed.
We are not discussing about some sophisticated setting or some issue appearing after heavy use.
This is plainly a hardware issue for products made end 2018.
DEAR FITBIT, MAKE A STEP FORWARD, ASSUME THE FAULT AND FIND QUICK SOLUTION
AS THIS IS THE RIGHT BEHAVIOR OF RESPONSIBLE COMPANIES
02-07-2019 22:56
02-07-2019 22:56
Bought my charge 3 on feb 7th and the white line appeared. I tried all the reboot/restart methods and had no luck. White line stayed. Until around midnight. My thoughts are somehow it fixed itself when it resets at midnight. Probly luck but idk.
09-27-2019 15:31
09-27-2019 15:31
I have the same issue and tried restarting but still the same
08-28-2020 11:52
08-28-2020 11:52
it did it to my charge 3, they want me to bu/y another charge 3 with a discount.
ONLY happened after the firmware update 8/20/2020
10-13-2020 12:31
10-13-2020 12:31
Same exact thing with mine. After the update I got the single line now a few days later it's become two. Also was offered discount to purchase no one. I call BS they messed it up with the update why should I have to buy a new one?!
