12-07-2018
21:21
14:34
12-07-2018
21:21
14:34
When I go to the "personal" section, all of these fields say "nothing to show" When I try to update using the scroll inputs and then try to save, it just says to enter a "valid" figure for one of the other characteristics. I have no idea what values are being used to calculate my results shown
12-08-2018 03:12
12-08-2018 03:12
Hi, @SunsetRunner, it sounds like you are trying to do this update on your web based dashboard (i.e. not on the phone app?)
On the personal settings it will not allow you to save any changes if it detects an error on the page. In this case one of the boxes will have a red message showing the error.
You should be able to change age, height, weight on your app (Windows 10/ phone / tablet if you use those.
If this doesn't solve your issue, please post again giving us a little more information about whether you are using phone (which one?) or web-based dashboard settings. There is always someone here to help, but as much information has you can give will help someone to find a solution for you.
Welcome to the forums!
Best Answer12-08-2018 20:35
12-08-2018 20:35
12-09-2018
02:52
04:03
12-09-2018
02:52
04:03
Hi, @SunsetRunner, this is what you would see (nothing to show) if you went to the personal section for one of your friends, or if you were looking at a child account.
To update your own info on your iOS app, I would recommend logging out of the app. Next log back in using the email and password you chose when you set up your Fitbit account. Make sure you choose "log in to Fitbit" and not "join Fitbit"
On the first screen click on the Account icon, top eight. The icon is meant to look like an ID card -- a small rectangle with a circle and 3 lines.
When the account screen opens the first item will be your name and "View your profile". Choose that. On the next screen select Personal, and you should have your details there and be able to update them.
If you have followed all these steps and you are still seeing "nothing to show" please post again. If possible, could you include a screen shot of what you are seeing? That could help to get to the bottom of it.
Best Answer12-09-2018 08:16
12-09-2018 08:16
02-09-2020 14:21
02-09-2020 14:21
I tried to update my information by logging in to this link https://www.fitbit.com/settings/profile
and it works.
