03-01-2021
19:32
03:11
AlvaroFitbit
03-01-2021
19:32
03:11
AlvaroFitbit
why does my Charge 3 Register me going up 22 stairs today when I only did one
03-02-2021 03:13
03-02-2021 03:13
@Jobill Welcome to the Fitbit Community!
Let me help you with this. Your device uses it's altimeter to detect variance in altitude. It will count 1 floor for every 10 ft it detects you climbed. There are situations that may affect the floor count like stormy weather (that has an actual impact on atmospheric pressure), gusts of wind, an AC unit in a closed room or opening a door. I suggest you start by cleaning the back of the device with cotton and rubbing alcohol then use compressed air at a distance to clear the altimeter's opening (small orifice in the back on your tracker). Finally restart it.
Hope this helps.
03-02-2021 06:45
03-02-2021 06:45
03-03-2021 11:11
03-03-2021 11:11
@Jobill sure hope this helps and thank you for giving my suggestions a chance.
See you around.
