05-12-2021
08:09
08:36
WilsonFitbit
05-12-2021
08:09
08:36
WilsonFitbit
I am trying to find out how to connect my device to my iPhone 11 Pro Max. “Fitbit” isn’t listed in my location services. I have read how to fix that but the info I was reading is incorrect. Do I need to delete and start over? I have a Fitbit Charge 3.
05-13-2021 04:59
05-13-2021 04:59
@doerlewine Thanks for your reply.
Regarding your question, the Charge 3 has what is called an inductive button and it is located at the left side of your device. It's not a traditional physical button. As mentioned on the post above, instructions for the restart can be found here.
Please check the picture below:
Hope this helps.
Best Answer05-12-2021 08:41
05-12-2021 08:41
Hello @doerlewine. Welcome to the community forums!
Thank you for the detailed information and for reading and following some troubleshooting steps. I'd recommend trying to perform a restart to your Charge 3. For this, please visit the following help article: How do I restart my Fitbit device?
Also, please confirm if this is the information you read before:
Hope this helps.
Best Answer05-12-2021 15:11
05-12-2021 15:11
Best Answer05-13-2021 04:59
05-13-2021 04:59
Hope this helps.
