10-09-2018
07:08
15:47
10-09-2018
07:08
15:47
Why isn’t my fit bit charge vibrating when I’m receiving a phone call? Text message and what app message come through but not vibrations.
10-10-2018 08:43
10-10-2018 08:43
@Nickypatel74 Welcome to our Fitbit forums! Let me find a solution for the vibration issue that your Charge 3 is experiencing when receiving call/text notifications. Please disable the notifications. After this, restart your tracker as described in this help article. After this, restart your phone, open the app and turn on the notifications again. Finally, sync your tracker and test the notifications in order to see if your tracker vibrates when getting a call or text message.
In the meantime, please let me know what is the model of your phone.
Looking forward to your response!
10-16-2018 14:53
10-16-2018 14:53
Doesn't vibrate still. Does not vibrate on restart boot up even. Will be returning.
10-18-2018 11:55 - edited 10-18-2018 11:57
@Roopert Thank you for joining us in this thread and our Fitbit Community! I'm sorry to hear that your Charge 3 is still unable to vibrate even though you have restarted it. Please check out this help article and make sure that your phone has this option enabled.
Let me know if you have any doubts!
11-21-2018 08:06
11-21-2018 08:06
Hello the same thing is happening to me. When I receive a call the screen lights up about one second then disappears, no vibration no notification. Have rebooted, checked settings, on Fitbit and on IPhone 8. Nothing works as it should. Using latest version off Fitbit app and charge 3 firmware. Very disappointed in the Charge 3 and have resulted in going back to using my Charge 2.
11-22-2018 03:57
11-22-2018 03:57
@HealthyJ Thank you for participating in our Fitbit Community! I'm sorry to hear that your Charge 3 is not vibrating when receiving call notifications either. Thank you for troubleshooting this issue before contacting the forums. Since the issue persists, let me go ahead and send your case to our Support team and they'll be happy to further investigate.
Let me know i you have any doubts!
01-09-2019 08:49
01-09-2019 08:49
Try this simple step (Step 3) of turning on the notifications on the Fitbit: https://help.fitbit.com/articles/en_US/Help_article/1979/?q=text+vibrate&l=en_US&fs=Search&pn=1#setu...
01-09-2019 09:10
01-09-2019 09:10
@Roopert, do you have vibration option enabled in the Fitbit app? When in the app, tap on a Charge 3 icon in the top right corner. Scroll down to Notifications, tap again. Scroll down - Always Vibrate option should be turned on.
01-24-2019 22:37
01-24-2019 22:37
Hi, I have the charge 3 and an iPhone and had the same issue. I have been playing around in the phone settings for days as I knew the Fitbit was set up to vibrate. I noticed the do not disturb had been switched on(maybe when setting up the Fitbit it caused this)yet I wasnt getting the normal message on the screen to say it was on..so disabled that and since then it has been vibrating when a notifications has come through. Might be worth a try 🙂
05-29-2019 14:33
05-29-2019 14:33
My notifications keep going off. Hold down on side button until notification and screen awake come on screen. Mine are usually shut off periodically so just tap them and you should be good!
06-25-2019 10:07
06-25-2019 10:07
Mine is doing this also.. It has never vibrated at all.. I have tried everything and all the solutions I have read What do I need to do?
Jodi
06-26-2019 10:22 - last edited on 02-21-2020 14:21 by LiliyaFitbit
I have also done eveything possible numerous times. My has never vibrated from the beginning. Can you please send my to support also..
07-19-2019 12:45
07-19-2019 12:45
That worked. Wonder why the notifications turn off.
07-22-2019 09:52
07-22-2019 09:52
I did not have an always vibrate option
07-31-2019 04:00
07-31-2019 04:00
Oh thats not good - mine has never worked either, I was hoping to come here to find the answer!
09-26-2019 05:01
09-26-2019 05:01
Thank you! Most helpful post on this thread.
09-28-2019 13:14
09-28-2019 13:14
My partner's charge3 wouldn't vibrate so I went into the app tapped notifications down to vibrate switched it off for 5 secs then back on and vibrate now works
12-17-2019 05:56
12-17-2019 05:56
How did you find out it was on silent/ do not disturb? Mine works for a short time then stops. It is annoying and I don't know how to fix it permanently. Thanks
12-18-2019 01:51
12-18-2019 01:51
My charge 3 was giving me so many issues from day one and kept switching it self off, the amount off times I had to reset it and in the end I took it back to the shop who also was baffled and sent it to service centre who claimed the watch was faulty. After going backwards and forwards to the store for 4 weeks I decided to get my refund and buy the Apple Watch instead.
01-16-2020 00:50
01-16-2020 00:50
Hi - I have this problem with my Fitbit Charge 3 not vibrating when my iPhone 6S rings ( it used to vibrate and I don’t know why it has stopped).I have tried the usual restarting of both devices.
Best wishes
David
