03-03-2017
17:37
12:51
EstuardoFitbit
03-03-2017
17:37
12:51
EstuardoFitbit
I have an old school Charge... no HR, not a 2. The band is very worn, but no one sells regular Charge bands anymore. Would a Charge HR or a Charge 2 band fit my Charge? Thanks!
03-04-2017 06:58
03-04-2017 06:58
No they will not. The Charge also doesn't not have changeable bands either.
Wendy | CA | Moto G6 Android
08-25-2017 08:04
08-25-2017 08:04
Did you get a resolve for this as I'm in the same position. Fitbit say they're not "interchangeable", but you can buy straps on ebay for the Charge 2 & the Charge HR. I've already removed the electronics which was easy enough - but obviously need a new housing now...
If you get an update - please post!
09-10-2017 04:27
09-10-2017 04:27
Same here. I've had three original Charge models. The first two straps just came away within the first year and FitBit kindly swapped them. Now the same has happened on my third and FitBit have offered a 25% discount of off a new purchase. Not an unfair offer but the device still works, I just want a strap. It seems silly that even if FitBit don't make an official replacement that the Charge HR doesn't fit.
09-10-2017 06:58
09-10-2017 06:58
I'd be interested to know if anyone has tried a Charge HR strap on the original Charge unit? Is it the same strap?
10-01-2017 10:43
10-01-2017 10:43
I would love to know the answer to this for sure. I have 3 Fitbit Charge. The electronics all work fine but the bands have all bubbled and otherwise come apart. Those straps are useless. I'd like to keep using my Fitbit but can't.
01-20-2018 15:14
01-20-2018 15:14
I attempted to get my Fit Bit charge to fit into a Fit Bit Charge HR band, doesn't work. Screws do not line up $12 down the drain.)
02-11-2018 21:59 - edited 02-11-2018 22:01
I have the same issue with the surge.
06-23-2018 15:03
06-23-2018 15:03
I know this doesn't exactly answer your question....
Yesterday at Target, I found a Charge 2 (the regular, not HR) band on clearance. I have the Charge HR 2 and needed a new band, so I bought it, and figured if it didn't fit my Fitbit I would just return it. Well it fits perfect.
I would tentatively say yes to your question, but it worked in reverse for me. Good luck!
06-24-2018 06:04
06-24-2018 06:04
06-25-2018 16:49
06-25-2018 16:49
Thanks for stopping by @Harbog, and @SunsetRunner! I appreciate your help and all your input. This is really helpful for us and keep us improving our products and services.
To clarify a little, at the moment the only trackers with interchangeable bands are:
I hope this helps, keep me posted! 🙂
10-05-2018 18:32
10-05-2018 18:32
I’m on my third surge band. I’ve ordered the replacement bands on AliExpress shipped to Canada for about $5 total. Easy little YouTube video walked me through the change with ease even though they are considered “not” replaceable.
10-11-2018 09:14
10-11-2018 09:14
Hello @Ferleyko, thanks for joining the Fitbit Community, it's great to have you on board.
I appreciate your participation in the Forums and for posting your findings. Please take in consideration that if your Fitbit device is still covered under the warranty, changing its hardware will automatically void it, nevertheless, I appreciate you have shared your opinion with us.
Thanks for your patience and understanding, have a great day.
12-10-2018 11:23
12-10-2018 11:23
Fitbit did not make the strap on the original Charge serviceable but has not taken responsibility for their mistake. The original charge with the substandard strap is completely useless without a proper strap. Fit bit's solution, after selling a completely useless product, of offering a 25% discount IF you buy another product from them is just pathetic and not taking responsibility for an egregious design error.
12-11-2018 07:44
12-11-2018 07:44
Hello @praitz, thanks for joining the Fitbit Community. it's great to have you on board.
I appreciate you have taken the time to share your feedback with us. Our team is always taking in consideration your suggestions, please note that due to the feedback provided by many users, the bands on newer trackers are detachable.
I sincerely apologize for the inconveniences this issue has caused you, please remember that we do not expect manufacturing issues to to affect our trackers but that's why every Fitbit tracker comes a limited product warranty and in case you have inquiries or doubts about what it covers, you can check it on this article: Return Policy & Warranty.
05-13-2019 14:14
05-13-2019 14:14
Hello!
does an Alta fit a Charge 2?
thanks!
05-14-2019 03:43
05-14-2019 03:43
useless response.....useless product if you can't even replace a band that fails frequently.....Fitbit should have refunded ALL customers.....I for one (and several friends/colleagues) will never buy another Fitbit product.....
05-15-2019 00:52
05-15-2019 00:52
@Maya35 fitbit bands tend to be different for each model so you can't use an Alta band with a Charge 2 (or vice versa)
