04-03-2016
15:25
17:01
04-03-2016
15:25
17:01
Hi! I received a replacement Charge because my current Charge is falling apart. When I set up the new one, will I lose all of my data (badges, history, etc)?
Thanks!
Moderator Edit: Edited title for clarity
04-04-2016 04:20
04-04-2016 04:20
Welcome to the Forums @aesavage5. Before setting up your new tracker, I recommend syncing the original one, in this way your information will remain on your Dashboard. After syncing the original tracker, you can setup the new one by doing the following from your iOS Fitbit app:
1. Go to "Account"
2. Tap "Set Up a New Fitbit Device"
3. Tap the image of the tracker you are going to set up
4. Tap "Switch to (tracker)"
5. Follow the instructions
Let me know how it goes! ![]()
04-04-2016 04:20
04-04-2016 04:20
1. Go to "Account"
06-25-2016 19:09
06-25-2016 19:09
I was sent a replacement Fitbit for one with a busted band. I noticed that in going through the setup procedures, all my previous badges were gone. Guess I have to start over.
Best Answer06-26-2016 05:12
06-26-2016 05:12
A warm welcome to the Forums @Richard002! It's weird to hear that your badges were gone. Did you paired your tracker to a new account? If you didn't, could you please log out and log back in to your account.
Hope to hear from you soon. ![]()
06-27-2016 10:04
06-27-2016 10:04
Best Answer06-28-2016 04:35 - edited 02-18-2020 08:26
@Richard002 Regardless of the user name that you used the most important thing is to have the same email address. If you used a different one then you automatically have a different account. You will need to access the other account with the original email address and setup your tracker there to see all your previously recorded information. I am not saying this happened but usually it is the case so I just wanted to mention it to you.
02-13-2020
14:11
08:25
AlvaroFitbit
02-13-2020
14:11
08:25
AlvaroFitbit
If I create a new Fitbit account will I lose my data on my old account?
Best Answer02-18-2020 09:32
02-18-2020 09:32
@Caleb225 A warm welcome to our Community! Sorry for the delay in my reply.
Thank you for your inquiry. If you create a brand new account you won't be able to retrieve or merge your previous information from a different account. You can either setup the new tracker to your existing account to keep that data or start from zero on a new account.
Let me know how it goes.
