03-27-2018 07:15 - last edited on 09-08-2020 18:54 by MatthewFitbit
I've previously been having no issues with my Charge 2 syncing with my WW app. It appears there was a Fitbit update overnight and now I can't sync my FB with my WW app. I've deactivated my Fitbit from the WW app, reconnected it, restarted my phone, etc. I feel like I've tried everything. Does anyone have any ideas?
04-24-2019 17:10
04-24-2019 17:10
Mine used to be synced but I got a new Fitbit and neither are linked anymore. I'm still have issues with them connecting
05-02-2019 06:19
05-02-2019 06:19
I'm having same problem Fitbit wont sync with ww app
05-16-2019 11:23
05-16-2019 11:23
Same problem, And WW has not fixed it yet. Same old story disconnect/reconnect wait 48 hours. My fitbit links to my iphone OK. But no info sent to the WW app. So my question is. Is it WW or fitbit?????
06-06-2019 01:45
06-06-2019 01:45
I can make link work once using the process discussed but only once. Next update requires another trip through the process
06-14-2019 16:14
06-14-2019 16:14
I am having syncing problems as well. It began with the latest Apple iPhone IOS update. I spoke with WW support and was told the update broke the ability to sync. I am assuming WW is still attempting to solve the problem as I’m still unable to sync.
07-14-2019 17:25
07-14-2019 17:25
All of my activity syncs from my Fitbit to WW app EXCEPT my weight! My husband has the same issue. We have tried all of the fixes, but the weight just won’t show up on WW.
07-14-2019 17:26
07-14-2019 17:26
07-15-2019 07:21
07-15-2019 07:21
07-30-2019 14:30
07-30-2019 14:30
Hi Alvaro, I just signed up for weight watchers and dowloaded the app. I am folling their intructions as to how to synch with fit bit but I cannit get it to work. Once it asks me to long in via Facebook, it just hangs. Any suggestions?
09-07-2019 17:05
09-07-2019 17:05
I think WW probably should amend their instructions. Mine wouldn't synch up until I accessed Apple Health (by going to the Profile, then the Settings gear, then Activity Settings, then Apple Health).Apple Health needs to be turned on.
09-12-2019 16:56
09-12-2019 16:56
Seems to still be some issue, I have tried a few times today and can't get the two apps to talk. I tried adding the device from my PC even.
How can I enter my activities manually?
11-11-2019 16:02
11-11-2019 16:02
To add your activities on WW, on the same screen you enter your food, just select the other tab that says activity. From there you just have to find the activity you did and then enter the time.
Hope that helps.
07-19-2020 12:11
07-19-2020 12:11
I have been trying these exact steps for the last few hours and nothing is working. I don't think I have ever been so frustrated. It makes me want to smash my FitBit to pieces. There has to be a way to make this connect. I tried contacting WW but they say they are not working due to the pandemic. Does anyone have any steps that actually do work?
09-27-2020 14:33
09-27-2020 14:33
I'm having the same problem since the last Fitbit update. I have disconnected and reconnected a few time. I end up with 5 out of 7 days syncing one week, only 2 days syncing from the next week, etc. I would love to have a solution as I bought a Fitbit purely because it links with WW.
09-27-2020 17:43
09-27-2020 17:43
10-01-2020 17:00
10-01-2020 17:00
I am having the same problem, I have tried everything! I am really frustrated because I just bought a new Charge 3 to replace the Charge 3 that I had about 20 months because the screen got so dim I could not see it anymore!!! Thinking of returning it!!!
10-01-2020 19:09
10-01-2020 19:09
11-12-2020 09:41
11-12-2020 09:41
I had the same problem trying to sync the two apps. I was able to finally sync them! 🥳. I had to use an actual desktop and log onto the WW website and it worked. I had been disconnecting from both apps on my phone with no luck. So hopefully this helps.
01-30-2021 19:12
01-30-2021 19:12
Tried all of this. Hours later, anger setting in and still not syncing....
01-30-2021 19:14
01-30-2021 19:14
Yes im going through this right now.. very frustrating. Did you ever get your versa to sync? If you did how?
