02-10-2016
13:51
05:03
AndreaFitbit
02-10-2016
13:51
05:03
AndreaFitbit
Hi, I am new to the fitbit experience. I have just recently purchased a fitbit and I've heard that when you rotate your wrist, the screen comes on. When I rotate my wrist, the screen does not come on. Is there anything I can do to make this work? Any help will be greatly appreciated.
Thanks
06-20-2017 06:51
06-20-2017 06:51
Thank you! Somehow I had turned my quick view off, so your answer worked perfectly to fix my problem before I whacked myself in the face trying to wake up my Fitbit 🙂
07-18-2017 10:57
07-18-2017 10:57
I just purchased a fitbit. when I lift my hand and rotate my wrist the display does not come on. can anyone assist.
thanks.
08-09-2017 04:51
08-09-2017 04:51
There is a setting on the tracker itself for quick view. Go to the logo, swipe left, go through exercise, fitstar, etc. all the way to the end where it says 'settings.' Tap, scroll down to 'Quick View', tap to turn it on.
10-10-2017 09:04
10-10-2017 09:04
Wrist rotation does not display clock face what can I do?
11-03-2017 08:17
11-03-2017 08:17
latest update would appear to turn off quick view and heart rate monitor. Go to settings and turn them back on. To the fitbit programmers I would say it is very upsetting to do an update and then find things don't work as a result of sloppy programming!!!!!!!!!!!!!
02-22-2018 10:47
02-22-2018 10:47
I can’t find it in settings? I can’t get it fixed?
02-26-2018 05:23
02-26-2018 05:23
Same problem. Bought this device two days ago ... seemed to work fine. Today, after a run the display no longer comes on when I flip my wrist. I do not seem to have the "Quick Display" option in my settings ... very sad.
03-09-2018 13:08
03-09-2018 13:08
Thank you!! I was beginning to think my FitBit was defective because I thought that feature was automatic. It's working now!
08-17-2018 12:30
08-17-2018 12:30
Thanks kalimm, followed your advise and now quick view works. Just had to turn it on in the fitbit app.
Best Answer08-29-2018 18:30
08-29-2018 18:30
Turn off the option to wake the screen when you turn your wrist; instead, tap the screen to turn it on:
12-06-2018 04:05
12-06-2018 04:05
If you have the Fitbit charge 3 you will need to hold the button on the side for 3 seconds for the quick view options.
12-06-2018 08:06
12-06-2018 08:06
Same here. That’s a very beginner programmer error for an update. Even the name of the setting is different.
12-15-2018 16:21
12-15-2018 16:21
I tried that thanks and that didn't come up on my face at all
Best Answer12-17-2018 11:10
12-17-2018 11:10
Hi @HankyPanky, welcome to the Community Forums! 🙂
Thanks for what you've tried to get QuickView to work for you.
To turn Quick View on or off, do the following:
1. Log into your fitbit.com dashboard and click the gear icon in the top right corner of the page.
2. Select Settings > Devices. If your account has multiple trackers, make sure the Charge HR is selected. 3. Turn Quick View on or off.
4. Sync your tracker.
Hope this helps. Let me know if you need anything else!
Best Answer12-30-2018 13:08
12-30-2018 13:08
Thank you so much, this worked and helped me so much... sometimes my hands are fun so I can't double tap the screen.
Best Answer01-21-2019 09:53 - edited 02-02-2019 08:49
The Fitbit Ionic is a bit quirky to fix. Press and hold left button on device. Brings up "Screen Awake." Change from Manual to Auto. "Settings" icon on device only gets you to "Display Awake" where you can adjust the time length the display stays lit. There's nothing under Settings for Screen Awake.
Best Answer01-23-2019 14:41
01-23-2019 14:41
Thank you!! It was driving me crazy! Turned out I also had the setting toggled off .
Best Answer01-26-2019 15:53
01-26-2019 15:53
I change the band on my Fitbit charge three and now at the wrist rotation does not display. Can someone tell me how to turn it back on please thank you very much !!
Best Answer02-02-2019 03:07
02-02-2019 03:07
Wrist rotation not working
