02-10-2016
13:51
05:03
AndreaFitbit
02-10-2016
13:51
05:03
AndreaFitbit
Hi, I am new to the fitbit experience. I have just recently purchased a fitbit and I've heard that when you rotate your wrist, the screen comes on. When I rotate my wrist, the screen does not come on. Is there anything I can do to make this work? Any help will be greatly appreciated.
Thanks
02-02-2019 05:07
02-02-2019 05:07
Press and hold the side button on your Fitbit charge 3 and select screen wake. Worked for me 🙂
02-07-2019 10:22
02-07-2019 10:22
This worked for my Fitbit Charge 3. I must have turned this off when I took it off and put it down on the bathroom counter. Thanks for the tip!
02-11-2019 18:08
02-11-2019 18:08
Thank you! Finally the answer!
Best Answer03-03-2019 04:29
03-03-2019 04:29
Very helpfully! Was driving me nuts!
Best Answer03-05-2019 14:39
03-05-2019 14:39
I have a Fitbit charge 3 and there is nothing in settings about the screen lighting up when you left your rest. But on the device itself there is a setting called screen wake. It was difficult to find. From the main screen hold the button in.
03-18-2019 20:18
03-18-2019 20:18
Thank you! This worked for me, I have the Charge 3 and wasn’t able to do what the others said to do!
03-27-2019 06:43
03-27-2019 06:43
Hi there, i tried that but mi fit bit does not have option, any other suggestion ?
Best Answer03-27-2019 08:59 - edited 03-27-2019 09:00
Daniela, on the Charge 3, hold down button on left side of charge. It’ll immediately say screen wake. Tap it and it looks lit on.
03-27-2019 13:13
03-27-2019 13:13
Best Answer03-31-2019 09:33
03-31-2019 09:33
Wrist rotation did work but no longer
Best Answer04-17-2019 23:20
04-17-2019 23:20
This video helped me fix it! https://youtu.be/07qm6i5fJcI
Best Answer04-17-2019 23:21
04-17-2019 23:21
This video will walk you through how to turn it on https://youtu.be/07qm6i5fJcI
04-17-2019 23:21
I agree. They moved it! Here's how to turn it back on https://youtu.be/07qm6i5fJcI
Best Answer04-23-2019 00:59
04-23-2019 00:59
Thanks, that's easily sorted it. No idea how I'd turned it off unless in my sleep! 🙂
13:31
09:32
JuanJoFitbit
05-16-2019
13:31
09:32
JuanJoFitbit
Thank you so much for your help. Something so simple but makes you wonder. My screen must have been changed to off by mistake when hitting the wrong button a time or two. Thanks again for sharing
On mine you don’t have to swipe to quick screen settings. You simply
press and hold button> select screen wake to turn on.
Moderator edit: merged reply
Best Answer05-24-2019 20:55
05-24-2019 20:55
Thank you!! Your answer is the only one I understood and it worked!!
05-27-2019 14:07
05-27-2019 14:07
My setting was wake...
Best Answer07-07-2019 03:45
07-07-2019 03:45
I have also lost the ‘Quick View’ setting. How do I get it back please?
Best Answer07-07-2019 08:10
07-07-2019 08:10
07-07-2019 08:25
07-07-2019 08:25
on the Charge 3, hold down button on left side of charge. It’ll immediately say screen wake. Tap it and it looks lit on. Hope that’s what you are looking for!
