02-10-2016
13:51
05:03
AndreaFitbit
02-10-2016
13:51
05:03
AndreaFitbit
Hi, I am new to the fitbit experience. I have just recently purchased a fitbit and I've heard that when you rotate your wrist, the screen comes on. When I rotate my wrist, the screen does not come on. Is there anything I can do to make this work? Any help will be greatly appreciated.
Thanks
07-07-2019 08:28
07-07-2019 08:28
Thank you Christine, its easy when you know how lol
07-08-2019 08:03
07-08-2019 08:03
07-26-2019 11:07
07-26-2019 11:07
Still not working even with instructions to click on gear icon since there isn’t one in the top right corner. Tried also changing settings on Fitbit itself. It was working until upgrade done
07-26-2019 11:20
07-26-2019 11:20
07-26-2019 11:35
07-26-2019 11:35
08-07-2019 04:25
08-07-2019 04:25
This is the simplest fix of all!! Thank you.
08-18-2019 11:09
08-18-2019 11:09
Thank you this is what I needed! Guess it got turned off at some point.
08-19-2019 19:03
08-19-2019 19:03
Wrist rotation not working
08-19-2019 19:27
08-19-2019 19:27
on the Charge 3, hold down button on left side of charge. It’ll immediately say screen wake. Tap it and it looks lit on. Hope that’s what you are looking for!
08-20-2019 04:05
08-20-2019 04:05
08-20-2019 12:00
08-20-2019 12:00
@Loobie1984 wrote:If you have the Fitbit charge 3 you will need to hold the button on the side for 3 seconds for the quick view options.
So helpful, many thanks. I was struggling to find the shortcut . Thanks
08-25-2019 23:54
08-25-2019 23:54
My fitbit rotation is not working
08-28-2019 14:05
08-28-2019 14:05
thank you so much! it worked
09-02-2019 20:42
09-02-2019 20:42
To y’all who is facing the issue with screen rotation, hold the left button on your device (watch) for 3 seconds, then turn on the ‘screen wake’ button, thank me later
09-09-2019 14:12
09-09-2019 14:12
Thank you! This solution worked perfect on my Fitbit Ionic.
09-30-2019 09:53
09-30-2019 09:53
Same problem
09-30-2019 10:53
09-30-2019 10:53
Hi,
Hold the left button on your device (watch) for 3 seconds and turn on the “screen wake” button,
Regards
11-29-2019 08:27
11-29-2019 08:27
wrist rotation not working what to do?
11-29-2019 11:55
11-29-2019 11:55
11-29-2019 19:28
11-29-2019 19:28
