03-08-2020
12:17
15:15
AndreaFitbit
03-08-2020
12:17
15:15
AndreaFitbit
My Fitbit is showing the wrong time, every time I sync it shows the time 1 hour ahead. I’ve checked settings and it’s correct so not sure why it’s doing this?! Any suggestions?
09-12-2022 09:07
09-12-2022 09:07
09-11-2022 14:30
09-11-2022 14:30
I am having the same problem. Did you ever get it sorted?
Best Answer09-12-2022 05:21
09-12-2022 05:21
Mine too fit it showing 1hr later than phone even with doing same as above. Can't sort any suggestions?
Best Answer09-12-2022 09:07
09-12-2022 09:07
10-11-2022 23:47
10-11-2022 23:47
You will need to sync your tracker to correct the time on it. Try restarting your tracker again but do this 3 times in a row by following these instructions: 1. - Plug your charging cable into the USB port and insert the other end into the port on the back of your 2.
Regards,
Will
