02-23-2020
15:48
10:23
02-23-2020
15:48
10:23
I charged up my Charge 2 and when I went to put it back on, its showing the wrong time of day. Tried looking at the app on my android to see if there was anywhere to check that setting but there doesnt seem to be. I tried switching it off and putting it back on, no change. Any suggestions?
02-24-2020 08:38
02-24-2020 08:38
You have to sync your tracker to set the time automatically.
Best Answer02-24-2020 15:42
02-24-2020 15:42
I have the same problem. I synced and time still hasn't changed. I tried turning off the option to sync to network and set the correct time zone. Time is still wrong. Any other suggestion would be appreciated.
02-25-2020 00:22
02-25-2020 00:22
02-25-2020 07:47
02-25-2020 07:47
Hi I’m just wondering how you did it? Having the same issue, stuck on yesterday’s date /time/steps (But the app is tracking all my information still)
02-25-2020 09:37
02-25-2020 09:37
02-25-2020 16:47
02-25-2020 16:47
Hi there! So the time on my watch and the app are correct, but When I look back at my data for my recent run I do not see any data for my heart rate and it shows that the time I was running was +3 hrs from Current time. This is now the 4th time this happened and it is getting quite frustrating! I've updated my application, made sure it is charged, resynchronized data and still no change.
02-26-2020 07:45
02-26-2020 07:45
I have same issue with god tracked walks last 2 days. Not sure what to do. Seems to be software and not have anything to do with device.
Best Answer02-26-2020 07:46
02-26-2020 07:46
Gps not god tracked.
Best Answer02-26-2020 08:45
02-26-2020 08:45
Best Answer02-26-2020 15:12
02-26-2020 15:12
I am having the same problem. Mine shows 8 hours difference in times after I sync and all my previous exercise history has changed times and has no HR data. I have updated the software to the latest. My daughter did not update and hers seems to be ok.
02-27-2020 01:31
02-27-2020 01:31
Same thing happened to me today after charging phone was totally flat had to do again was fully charged the 2nd time but now the time is totally wrong
Best Answer02-27-2020 01:33
02-27-2020 01:33
How do you since tracker for auto time?
Best Answer02-27-2020 09:38
02-27-2020 09:38
02-27-2020 14:06
02-27-2020 14:06
Similar here. Watch and app time are correct, but my workouts are being split. The heart rate/steps have the correct time, but the GPS data registers as five hours in the future. I am US Eastern time, so I am guessing the five hours in the future is related to GMT.
