10-13-2018
		06:26
		15:06
		10-13-2018
		06:26
		15:06
Hi I just received my Charge 3, however it is set up on German language.
how do I change it to English?
There is no option on the watch and I did not found in the app as well.
could somebody help me?
10-13-2018 06:51 - edited 10-13-2018 06:52
Good afternoon illes19
Here's a direct link to the Help Article: https://help.fitbit.com/articles/en_US/Help_article/1536
HOW DO I CHANGE THE LANGUAGE ON MY TRACKER OR WATCH?
Your tracker or watch must use the same language as the language you use for your Fitbit account.
To change the language on your tracker or watch:
Regards,
Skyrider
10-13-2018 06:46
10-13-2018 06:46
I think you need to go to the settings in your online fitbit account, into personal info and the option to change language is there.
 Best Answer10-13-2018 06:51 - edited 10-13-2018 06:52
Regards,
Skyrider
10-13-2018 14:05
10-13-2018 14:05
Hi! I have a similar issue.
I received my Charge 3 yesterday and when I downloaded the app it was in German. I followed the mentioned instructions (change country on the app) but it keeps setting itself back to German. The most weird right now is that it's partially in English and German. I made screenshots but don't see where I can atrach them.
 Best Answer10-13-2018 14:23
                              10-13-2018 14:23
To attach screen shots, click the 'Photos' icon with picture of camera just above box where enter text.
Don't know if it will help in your case, but sometimes when changing a setting doesn't seem to work, it helps to first change it to something else wrong that you don't want, sync, then change it back to what you want and sync again.
10-13-2018 14:30
10-13-2018 14:30
Great, it English now.
This situation has motivated me to learn German language.
 Best Answer12-08-2018 10:18
12-08-2018 10:18
I don’t understand. I always had my time zone automatically detected with Sweden selected on Charge 2 and I had the menu items in English. Why is it all in Swedish on Charge 3 now??
 Best Answer12-08-2018 10:29
                              12-08-2018 10:29
Hi, @mrsgustafsson, I think Fitbit has in the past year or so made some changes in how the language and time zone interaction works.
Your language will be determined by which country you set up, and this is done on the web based platform rather than the app. If you want your language to be English, you shouod set your country for UK in the web based settings. You can then set your timezone to Sweden in the app. My experience is that when Fitbit does an update you may need to reset these preferences.
 Best Answer04-18-2019 02:08
04-18-2019 02:08
"Your tracker or watch must use the same language as the language you use for your Fitbit account."
This doesn't work for me. My account is in English, yet my tracker is still in Dutch.
In Advanced settings I have selected "Nederland (Engels)".
Any ideas please?
 Best Answer04-18-2019 02:11
04-18-2019 02:11
UPDATE: There's also an "Europe (English)" option which worked!
04-18-2019 02:18
04-18-2019 02:18
Wow! Thanks! It really worked!
 Best Answer06-11-2019 11:14
06-11-2019 11:14
I am having the same issue..I have to reset language in my profile Everytime my Fitbit does a sync 😞
 Best Answer06-11-2019 15:23
06-11-2019 15:23
@Kf13039 wrote:I am having the same issue..I have to reset language in my profile Everytime my Fitbit does a sync 😞
Yeah, unfortunately for me it also worked for a while only 😞
 Best Answer07-23-2019 06:17
07-23-2019 06:17
Stating the obvious - country is not the same as language. Numerous countries of several or no official language, not to mention many who work in a country but use a different language.
 Best Answer05-21-2020 12:20
05-21-2020 12:20
Hi,
While i can change tha languge the way it has been described, the language keeps changing back to Swedish for some reason.
Can you explain why it does.
It does it as of March-April. i have had Charge 3 since December 2018, it has not been a problem before, only recently.
I have tried contacting Fitbit support over email, but no response on the matter.
please advice urgently.
 Best Answer05-22-2020 01:59
05-22-2020 01:59
I had the same issue - device in Dutch but app in English. I live/work in the Netherlands but speak English. None of the 'change language' options worked for me - even Nederlands(Engels) made the device in Dutch. But I changed the location setting to Europe and now device seems to be in English.
