11-20-2016
14:22
10:26
11-20-2016
14:22
10:26
The fitbit charge 2 made me have numbness and I need to return it to the store. How do I factory reset the charge 2? Is it true that you can't factory reset it? I don't want to return it with my info on it.
11-20-2016 15:28
11-20-2016 15:28
That's correct @gammie4ll the Charge 2 doesn't have a factory reset. May I ask what information of yours you think might be on it?
It has your step count, stride, and maybe your BMR, plus an address that the server uses to determine the Fitbit account that the tracker links to. So yes ir will display todays steps, but the get reset at midnight,, so tomorrow are gone. Now if the tracker is removed from your account, then there is not account linked to the tracker.
11-20-2016 15:28
11-20-2016 15:28
11-20-2016 21:13
11-20-2016 21:13
One of the things you can do is to remove the device from your account before returning it. To do this, go to the Dashboard, click on the Cog wheel in the upper right of the Dashboard. Click on the Charge 2 icon. If you then scroll down to the bottom of the page, there is an option to remove the Charge 2 from the account.
12-03-2016 09:24
12-03-2016 09:24
I know this has been solved and my question relates to removing from account. If I remember a device from my account, would it be on the setup screen if somebody else goes to use it (say if I want to gift it)?
12-03-2016 10:21
12-03-2016 10:21
To remove the device from the account. follow the advice in my previous post on how to remove the device from an account. You click on the cog wheel in the upper right hand corner of the Dashboard, click on the appropriate device icon and then scroll to the bottom of the ensuing page and click on "Remove Device from Account."
03-11-2017 12:40
03-11-2017 12:40
There is no cog wheel on my dashboard. Any other suggestions
03-11-2017 14:06 - edited 04-11-2019 15:31
Hello @SunsetRunner I see this is your first post in this thread.
Since there are 5 different dashboards and 3 have an old and new version.
Which dashboard on what device do you have what question about?
04-08-2019 06:06
04-08-2019 06:06
Instead of using the app, go to the website and log into your account. There you should be able to to see and remove your Fitbit.
