05-08-2017
09:36
09:49
05-08-2017
09:36
09:49
After the new update to the app (don't know if it has anything to do with it) my charge 2 went from holding charge for at least a week to not even a day. It has been the last 4 days it will die before the day is over.
05-09-2017 08:51
05-09-2017 08:51
Hello @Meganleigh7985, it is great to see new faces aboard! 🙂 Hmmm this sounds extremely weird. I recently updated mine too and is not giving me battery issues at all. Let me suggest you something, there are some tips in this post to make the battery last longer, so I urge you to take a look at them and in a few days see if they work. In addition, you could also try to restart your Fitbit, fully charge it and keep an eye on the battery life through the days.
Let me know how it goes!
05-29-2017 12:56
05-29-2017 12:56
Same thing. Charge may last anywhere from 1 to 3 days......
@Meganleigh7985 wrote:After the new update to the app (don't know if it has anything to do with it) my charge 2 went from holding charge for at least a week to not even a day. It has been the last 4 days it will die before the day is over.
05-30-2017 07:04
05-30-2017 07:04
Welcome to the Community @almostfit2017! Oh! The battery of the Charge 2 should last up to 5 days with normal use. It could last longer depending on how many features you have on or you are using (Notifications, reminders to move, etc.) so I would like to know if you have followed the instructions that I posted above to make the battery of your tracker lasts longer. If the issues persists, let me know and I will help you out!
Have a nice day!
06-17-2017 05:16
06-17-2017 05:16
I have this issue. I did the battery saving shut-offs and tried to reset several times. Bought these in Feb. You would think the battery would last longer than that. Ant help?
06-17-2017 06:55
06-17-2017 06:55
I reset my Fitbit and I stopped charging it before it goes dead and it has helped a lot!
06-17-2017 20:10
06-17-2017 20:10
I tried that. Didn't work for me.
06-20-2017 08:02
06-20-2017 08:02
Hey @Meganleigh7985, it is great to see new faces around! 🙂 Thanks for posting the tips that helped you out with the battery of your Charge 2.
@Coachb48423, I appreciate you have tried some steps to make the battery of your Charge 2 lasts longer. Have you tried to clean the contacts on your Charge 2 itself and also on the charging cable? If you have't, please take a look at these tips:
06-20-2017 19:00
06-20-2017 19:00
The issue is not that it doesn't charge, it is that it doesn't HOLD a charge. When it is fully charged it last about 2-3 hours before it goes dead. I thought it was supposed to last 5-7 day. For it only being 4 month old this can't be right.
06-20-2017 19:12 - edited 06-20-2017 19:14
My charge 2 is doing the same exact thing. I was working Sunday, Monday I put it on the charger, it wouldn't charge. It finally charged and lasted maybe 40 minutes before it went dead again.
06-21-2017 07:57
06-21-2017 07:57
Hello guys! I hope you are doin' fine!
@Coachb48423, Oh! I apologize for the misunderstanding. In order for us to further assist you, please take a look at your inbox. 😉
@tvgurl, welcome to the forums! Did you try the instructions that I posted above to make the battery of your Charge 2 lasts longer? If you haven't please take a look at them and let me know how it goes.
Catch ya' later!
06-21-2017 11:33
06-21-2017 11:33
I have noticed that my Fitbit charge does not last as long as it used to. It used to last about a week, but the past couple of weeks, I have noticed that it is only lasting 4-5 days. I'm not doing anything different.
06-21-2017 17:24 - edited 06-22-2017 22:19
Yes I have tried everything.....my charge 2 is only 6 months old....I can't believe after 6 months it just starts to malfunction. Wow!
06-22-2017 12:59
06-22-2017 12:59
Hey guys! I hope that you are doin' great!
@Kac52095, have you tried the tips that I posted above in order to make the battery of your Charge 2 lasts longer? If you haven't, please give it a try and let me know. 😉
@tvgurl, In order to get further assistance, please take a look at your inbox.
Have a nice day, folks!
07-05-2017 08:49
07-05-2017 08:49
My problem is solved. Customer service said battery was bad. They sent me a new one and it works perfect. One week on this charge and I'm still at 45% battery. Customer service was exceptional. Very pleasant to talk to and quick to take care of my problem. Thanks so much.
07-05-2017 14:10
07-05-2017 14:10
07-05-2017 14:32
07-05-2017 14:32
@Coachb48423 wrote:My problem is solved. Customer service said battery was bad. They sent me a new one and it works perfect. One week on this charge and I'm still at 45% battery. Customer service was exceptional. Very pleasant to talk to and quick to take care of my problem. Thanks so much.
I would also like to know how they came to the definitive conclusion that the battery was the issue.
Perhaps that is everyone's problem which would call for a massive recall!
Lee
Lee
07-09-2017 08:45
07-09-2017 08:45
Fitbit saw that it was a battery issue. I just received a new one. I'm happy again. 🙂
Thanks Fitbit customer service!!!!!!!!
07-09-2017 11:55
07-09-2017 11:55
I have the same problem as everyone here, I haven't changed anything in my using the Fitbit charge 2 and the battery life has become short for only a few hours.
Nothing helps I tried everything that was written in this post
07-10-2017 06:30
07-10-2017 06:30
Hello guys! I hope you are doin' great!
@Coachb48423 and @tvgurl, sounds pretty cool that Support helped you out with this and will send you a new Charge 2 as a replacement. If you need help with your new trackers, let me know. 😉
@Lee-LA I would like you to let me know if you already tried the tips that I previously posted to make the battery of your tracker lasts longer.
@Amosc91, I appreciate you have taken the time to fix this issue with the battery of your Charge 2. Since this persists, I need you to take a look at your inbox so you can receive further assistance.
@Kac52095, I would like to give a hand on this, so please review your inbox.
Catch ya' later guys!
