06-26-2019
03:51
15:06
06-26-2019
03:51
15:06
My charge 2 last 10 mins and then dies. I’ve reset it
Fitbit 2.95 (839)
version 22.55.2
06-27-2019
08:22
11:20
06-27-2019
08:22
11:20
@Rwfit Welcome! Thanks for being part of our Community!
Let me help you with your Charge 2 not holding a charge and thank you for restarting it. Try cleaning the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves.You can also find additional suggestions here.
Let me know how it goes.
Best Answer07-08-2019 02:48
07-08-2019 02:48
Best Answer07-08-2019 17:51
07-08-2019 17:51
Having the same issues. All of a sudden after a "full charge" my band only lasts an hour. A week ago it lasted 4-5 days on a charge. If it was a pure battery issue the decline wouldn't be so rapid, as with a phone or other lithium battery devices.
Best Answer07-08-2019 18:53
07-08-2019 18:53
Im having the same issue. My band worked just fine last week. I charged it all night and it shows a FULL CHARGE, but doesnt last over an hour.. I want a replacement these bands are too expensive for them just to quit working.
Best Answer07-09-2019 00:21
07-09-2019 00:21
