09-11-2022 23:16
09-11-2022 23:16
I have experienced a trouble which is pairing issue with my android phone.
My tracker is 'Charge Hd' that i had used for a long time and I haven't used for an year.
The issue I have is pairing with only Android phone.
After pairing code is entered into App, pairing process is on going and connection failure message comes out again and again.
I tried to factory reset? and error code 0x0009 was seen on display. (normally error code should be seen 0x0001 during the reset process, as I know)
This issues is undergone over and over.
Weird thing is that it perfectly pairs with my iPhone 13..
Is this device hopeless using with Android Phone?
09-11-2022 23:46
09-11-2022 23:46
Ways to fix-
1) Start your device and log on as an administrator.
2) Click the Start button then select All Programs, Accessories, System Tools, and then click System Restore.
3) In the new window, select "Restore my computer to an earlier time" option and then click Next.
4) Select the most recent system restore point from the "On this list, click a restore point" list, and then click Next.
5) Click Next on the confirmation window.
6) Restarts the computer when the restoration is finished.
Novice Computer User Solution (completely automated):
1) Download repair utility.
2) Install program and click Scan button.
3) Click the Fix Errors button when scan is completed.
4) Restart your device.
Regards,
Rachel Gomez
