12-23-2016
04:16
10:13
12-23-2016
04:16
10:13
how do I know it is fully charged?
04-21-2018 08:18
04-21-2018 08:18
But even if you press the button, you can't see anything. The screen is covered by the charger.
Best Answer04-21-2018 08:20
04-21-2018 08:20
I think you may have the charger the wrong way round. It clips from behind so you can see the screen.
04-21-2018 08:21 - edited 04-21-2018 08:25
Are you sure that you have a Charge 2? There really is no way that its charger can cover the screen.
How do I charge my Fitbit device?
I generally pick the unit up and look at the display. Now it is easy to tap the button or unplug/plug in and the level will be displayed .
Or sync the unit and the app will display the current level
Best Answer08-16-2019 08:53
08-16-2019 08:53
How do I know my Fitbit charge 2 is fully charged. Thank you
Best Answer08-16-2019 11:10
