06-17-2022 07:06
06-17-2022 07:06
When I set a new alarm for my Charge 2 using the Fitbit iPhone app, it creates two alarms, showing identical times. This happens whether or not the alarm is set to repeat.
The first of the two is synchronised with my Charge 2. The second gets labelled "Not Synced Yet". If I attempt to delete the unsynced alarm, it is then synced. If I then delete it and go back to the Charge 2 screen in the app and tap "Sync now", the duplicate is finally deleted.
Has anyone else experienced this?
Is there some fix I can apply, or should I just report a bug?
Thanks in anticipation,
Chris Woodhouse
06-23-2022 19:32
06-23-2022 19:32
Thank you for visiting the Fitbit Community, @shed53.
I’m sorry to hear about the difficulties you experienced with your alarms. Thank you for the time you spent trying to get them resolved.
I noticed that you've been in touch with Customer Support. I'm pretty sure they will do their best to provide a high level of support. Thank you for your patience while dealing with this situation.
Have a nice day.
Best Answer09-01-2022 12:47
09-01-2022 12:47
This happens to me too on my Inspire 2, please can you help? There is currently an alarm which duplicated and I can’t delete it because it is greyed out. It’s very frustrating having to keep deleting duplicates!
Thanks
Best Answer09-01-2022 15:11
09-01-2022 15:11
Getting a greyed out alarm sometimes happened to me. I found no way to remove it other than the nuclear option. I would sync my Charge 2 with my phone, then remove it from the phone, factory reset the Charge 2 then set it up in the iPhone app as a new device.
Fitbit support eventually pinned their hopes of solving the duplicate alarms fault on v3.64 of the app but that made no difference. At that point they metaphorically threw their hands in the air and said they couldn’t do anything further.
Sorry I can’t be of any more help.
Good luck!
Chris
09-02-2022 01:26
09-02-2022 01:26
Doesn’t sound promising then, but thanks for your reply Chris.
Claire
