03-12-2016
23:25
20:15
03-12-2016
23:25
20:15
03-13-2016 16:51
03-13-2016 16:51
Hey @Jocelynk very welcome to the Community! Well, the Charge HR wristband is made of elastomer material similar to that used in many sports watches. It does not contain latex. The buckle is made of surgical-grade stainless steel. While all stainless steel contains nickel and may cause an allergic reaction in someone with nickel sensitivity, the amount of nickel in all Fitbit products meets the European Union's stringent Nickel Directive. However, I recommend contact Customer Support in order to find more information about this.
. In addition, let me share with you the Wear and Care page for cleaning instructions and care tips.
Let me know how it goes! ![]()
If this post was helpful vote for it or accept it as a solution! Remember challenge yourself and become better than yourself. Share your story!
03-13-2016 18:04
03-13-2016 18:04
Best Answer03-24-2016 16:54
03-24-2016 16:54
Thanks for clarifying @Jocelynk!
You can use your Fitbit tracker in your other wrist, you just need to log into your Online Dashboard in Fitbit.com and click on the Gear Icon (upper right corner) and click on Settings, select devices and scroll all the way down to Dominant, finally sync your tracker. The information will be accurate as if you were using in your other wrist.
I hope this info helps you, let me know if you have any additional question!
12-29-2019 07:58
12-29-2019 07:58
I experienced the same pain after the third day and night wearing the Fitbit.
My metal plate and pins were added during wrist surgery 6 years ago
i have followed the steps to switch the Fitbit to my dominant wrist.
Pain was quite intense!! Troubling actually as it was painful enough to wake me last night!
