09-12-2016
12:08
10:26
09-12-2016
12:08
10:26
Unpacked my Charge 2 and I get a screen with the Fitbit logo and "www.fitbit.com/setup". I already have a Charge, so I'm all set up. How do I get the Charge 2 past this boot screen?
01-28-2017 20:49
01-28-2017 20:49
Found the problem - I didn't sync it with Bluetooth. All good once I did that.
Best Answer01-28-2017 20:53
01-28-2017 20:53
I had the same thing and finally got it by connecting/pair to bluetooth on my phone and it finally worked
Best Answer01-29-2017 15:28
01-29-2017 15:28
Hi guys. Someone may find this useful. If you are upgrading from a Charge to a Charge 2 you need to go down the add a device route NOT the replace a device direction, as you are not replacing like for like. (You can delete your old Charge later). This worked instantly for me after trying for hours to get past the initial setup screen on my new device.
02-12-2017 17:18
02-12-2017 17:18
I'm in the same boat I guess. I'm using a Mac and a Charge 2, can't get through the initial setup as the fibtbit connect app hangs on the "please turn on bluetooth" panel.
New to fitbit, but created user account earlier. Today got the Charge 2, went to www.fitbit.com/setup, logged in, installed the mac fibtbit connect app, selected Charge 2, pressed the power button on the Charge 2, the display comes on (and just says www.fitbit.com/setup), then I get to the page that says "please go to system preferences to turn on Bluetooth".
Went to system prefs and Bluetooth was already on. It lists two devices, both as "not connected." No idea which, if either, is my charge 2. There's another choice on the system prefs Bluetooth page-- "discoverable", which is off. But I'd since the app didn't tell me to enable that, I'd like to see some real documentation explaining whether I need that before I just start flipping switches on and off willie nillie.
No idea what to do next. The fibtbit connect app won't let me move on to the next step, and doesn't appear to have any other options. The *only* instructions that came with the product are "www.fitbit.com/setup". Unless there are other instructions hidden in the box somewhere.
Best Answer02-13-2017 03:59
02-13-2017 03:59
Best Answer04-21-2017 10:34
04-21-2017 10:34
trying to setup my new charge 2. Had a charge before. went through the process but fitbit screen is stuck on ww.fitbit.com/setup. Cant get it out of that. Can't restart. Apparently this is not an unusual issue...
wish there was simply a tech help one can connect with
04-21-2017 17:09
04-21-2017 17:09
I would love to help, but will need more details. Are you guys following tye setup guide at http://help.fitbit.com/articles/en_US/Help_article/1873/
It als9 would be helpful to know at what step durring the setup, the process fails.
05-14-2017 15:50
05-14-2017 15:50
I have the same problem (just opened my fitbit charge 2 this afternoon), and it's stuck on the setup screen, and when I plug it in to charge, I don't get the battery-charging display it looks like I'm supposed to see. Will it still charge stuck on the setup display?
Best Answer05-14-2017 16:43 - edited 09-05-2018 12:36
It is not stuck on the setup screen, it is politely waiting to be setup.
As for the charg8ng indicator, you won't see it until the tracker is setup.
Download the Fitbit software or the app, choose tye "i have an account", log in and follow the prompts to add the tracker.
06-01-2017 17:48
06-01-2017 17:48
Rich hoping you can help me cause I've about had it.
IPhone 6
charge 2
Stuck in setup mode
fully charged
found tracker
received code and entered code
app keeps trying to pair with charge2
no success still scrolling Fitbit setup on screen.
06-02-2017 04:03
06-02-2017 04:03
exact same problem here. i used online chat and also called, both said i have a dud (my words not theirs, they were quite kind and willing to try to help) and need to return the device. I'm willing to try other things before returning it, but if there is a design flaw i would return as opposed to exchange
attempted with ios on iphone 6, ipad, also windows.
Best Answer11-29-2017 07:20 - edited 11-29-2017 07:23
I tried setting it up via my computer and downloaded the app, but it wouldn't let me sync my fitbit charge 2 without purchasing a "wireless sync dongle." That didn't seem right, so I assumed I had to charge it more, even though it was already charged for hours. I woke up the next day, I was still stuck on the "www.fitbit.com/setup" screen. I decided to download the app from my phone to see if it would sync and it worked! It synced through bluetooth. Not sure why it didn't work on my computer.
Best Answer12-25-2017 05:35
12-25-2017 05:35
THANK YOU! Got my new HR2 for Christmas and was super frustrated after having charged it and followed most of the instructions higher up in this thread.
Best Answer12-28-2017 16:41
12-28-2017 16:41
The "solution" points to a broken link. There is no "replacement setup process" there.
02-25-2018 07:12
02-25-2018 07:12
Thanks to all the responses - immensely helpful. After I charged mine overnight, everything in set up process worked perfectly. Thanks again!
Best Answer09-05-2018 06:33
09-05-2018 06:33
I have had my Charge 2 for some months now. Suddenly it is only displaying 'fitbit.com/setup' on screen. I have tried a reboot. When I log into my account it doesn't have the connection to the charge. Please advise.
Best Answer09-05-2018 12:37
09-05-2018 12:37
@p8089996 please go to your app and fo an add device, then follow the prompts to add your Charge 2
09-18-2018 11:50
09-18-2018 11:50
StephAStephan. What was the number that you called? What info did you have to give them? Since I am stuck on setup screen.
Best Answer09-18-2018 14:20
09-18-2018 14:20
Hello @Dahsm may I ask at what step if the setup process does it fail, and what device are you using to setup the tracker?
Let's look at the setup process
09-18-2018 14:28
09-18-2018 14:28
Rich. Hi. I was going through the setup process to the point where a four number verification code appeared on my tracker and I entered that number on my Samsung Galaxy tablet fitbit app.Then the app took me to my dashboard, where I can set goals, etc, but tracker is still in setup mode. The interesting thing is that the fitbit seems to be counting my steps and the total steps appear when I open the app. I have been charging it for four hours. During the original "setup" process, the tracker was synced with my tablet, but will not sync now. As suggested, I will charge overnight, but not optimistic that will help
