"403: forbidden" error on Charge 3
ANSWERED
Hi! I've been trying, for a week now, to add my card to my Fitbit wallet. But it keeps on showing error 403: forbidden.
I've talked with the bank and they said that the card was authorized for Fitbit. I've talked with customer service through Twitter, did everything they told me to do, deleted the app and restarted the phone 3 times, and nothing works.
I've been able to add a card before, but now it's not letting me and it is frustrating. Does anyone had this problem and knows the solution?
Thanks!
1 BEST ANSWER
Accepted Solutions
Hi,
That doesn't really help. The real problem is the sync between the app and your system. I followed the steps provided at this post: https://community.fitbit.com/t5/Ionic/Getting-Error-403-Forbidden-when-trying-to-add-Credit-Card/td-...
And it worked immediately. So, if everyone if having that error when trying to add a card to "wallet", try this first. Installing and uninstalling the app doesn't work at all.
3 REPLIES 3
Welcome to the Community, @paoquintero.
I understand how are you feeling and appreciate all the efforts in trying to fix this 403 error. For more information about this problem, I recommend taking a look at this post and follow the steps provided there.
Let me know if you need anything else. 🙂
Hi,
Thanks for the update and for the information, @paoquintero.
I am glad to hear that this steps worked and that your tracker is now working properly. If there is anything else we can help you with, do not hesitate to post it.
Keep the stepping up! 🙂
