08-04-2020 07:02 - last edited on 12-14-2022 16:17 by MatthewFitbit
My Fitbit states: "Cannot establish a GPS Connection. Turning GPS off." I cannot get my Fitbit to go to any other screen. I have tried swiping up and down and left to right.
I got to the GPS screen accidentally when I was looking for the alarm screen. My Fitbit has not had this on the home screen for more than 12 hours. I have tried:
Any help will be greatly appreciated.
Thank you in advance.
Tobey A
08-04-2020 07:52
08-04-2020 07:52
Hi, I hesitate to offer advice as I've only had mine for a week. If you are at the GPS screen try taping the face with your finger alternatively a short press on the side button. If you can get to the settings screen go down to "about" and press reboot. I've had mine hang up on me while using GPS (see other threads for problems with GPS - which we think Fitbit are looking at) and eventually got it working but can't remember exactly how.
Gr4ndp4 | UK
08-04-2020 07:52
08-04-2020 07:52
Gr4ndp4 | UK
08-04-2020 07:58
08-04-2020 07:58
Also, see thread Charge 4 screen wake not working
Gr4ndp4 | UK
10-11-2020 20:48
10-11-2020 20:48
Mine does this almost every time I use it. I have used the dynamic setting and the use phone GPS setting, and it doesn’t seem to make a difference. Very annoying.
11-22-2020 18:54
11-22-2020 18:54
Only built-in GPS works reliably on my Charge 4, and of course, that's sucks down the power so it only works for relatively short rides. The other options fail various ways but generally just don't record anything at all or display "lost GPS connection, stopping" (or something similar) on every ride or run. Extremely frustrating.
02-11-2021 08:02
02-11-2021 08:02
Welcome to the Community, @Ms_Tobey_A and @fwulf. @goterps75, it's great to see you here and @Gr4ndp4, thanks for the input.
I understand how are you feeling and appreciate all the efforts in trying to fix this GPS issue. If you are having problems with this feature, I recommend taking a look at the help article: Why isn't GPS working on my Fitbit device? and follow the instructions provided there.
Have a good day!
04-12-2021 04:19
04-12-2021 04:19
Hi there, has there been any recent resolution or patches to fix this. I'm wondering what else I can do, the gps just seems to have given up. Also the screen wake when I flick my wrist to view the display is off ..I've not changed any setting.
I've only had mine since last Xmas and it's getting all wonky unfortunately.
Kind regards
Nesh
04-12-2021 08:00
04-12-2021 08:00
04-12-2021 09:15
04-12-2021 09:15
Yeah, it's a shame because it worked so well for the first 2 to 3 mths, then just seems to have hit the skids .. I like the basic functions, the displays e.g. split time display with the GPS - nice n easy but wasn't expecting reliability issues to be quite so prevalent.
04-13-2021 07:14
04-13-2021 07:14
Well at least it's consistent. Was the same today on the run, the GPS cuts off exactly around the 11.5 minute mark..on each reset.
Is there a way to get a replacement tracker?
04-13-2021 14:21
04-13-2021 14:21
Mine's doing this! 11 mins 10 seconds 6 or so times in a row.
04-24-2021 08:24
04-24-2021 08:24
04-27-2021 09:12
04-27-2021 09:12
Yeah for real! I kept trying to track my walk using the phone GPS, and it kept dropping at 11 min with the stupid "unable to establish GPS connection..." error.
I'm really thinking about returning this lame Charge 4 and going back to the Charge 3! I bought the 4 thinking it was an upgrade with the SpO2, etc., yet I still haven't been able to access that feature after two weeks...
What a letdown!
04-30-2021 17:42
04-30-2021 17:42
Gr4ndp4, great advise, that worked for the "cannot establish a GPS connection" screen, but the FITBIT is not working/tracking my activity at all. I have been using a track 2 for 2 years, and tonigh is back to track 2.
09-25-2021 12:08
09-25-2021 12:08
Hey y'all - I was having this issue and opened a support chat with Fitbit. They had me do all the usual stuff (charge, reset to defaults, reboot) but it was the same result. Then they asked me to mail it in w/o explanation. They obviously knew something that I didn't (and didn't share the details). Got a replacement and now I'm not getting the dreaded "Turning GPS Off" message. Something is clearly different in the hardware as the software versions are the same.
09-28-2021 00:48
09-28-2021 00:48
Good to hear that the good folks at Fitbit offered you a replacement - I'd reckon that's probably the best way forward.. however how do they decide who gets a replacement or otherwise. Curious.
I've just learnt to live with the issue however it's a shame given I was quite hyped when I had my charge 4 .. now the 5 is being promoted.
09-28-2021 13:24
09-28-2021 13:24
I've experienced this problem too but I seem to have found a way to make it work:
First, open the Fitbit app and then click on the "+" for manually tracking exercise. This is just to get the app to update your current position.
Second, on your tracker swipe to the Exercise option and tap, then select the type of exercise and tap start. Now wait until "Connected" is displayed then tap to start. If you start without waiting for the GPS to be connected it will fail to connect (at least that's my experience). For me that usually takes about 30 seconds.
I have a feeling that the app may not be allowed to access the GPS if you don't follow these steps.
I only have the tracker use the phone GPS because using the built-in GPS the battery dies way too fast.
09-30-2021 20:30
09-30-2021 20:30
Tonight I went for a walk and I followed the steps I outlined above. Once the GPS was connected I put my phone in my right back pocket. After about 15 minutes the GPS lost connection. I stopped the exercise and restarted it but put my phone in my left back pocket - same side of my body as the tracker - and it stayed connected for my entire 90 minute walk. It seems it may be very sensitive to the location of your phone.
09-30-2021 20:36
09-30-2021 20:36
Thank you Bill. I guess the problem is for runners who head out only with the tracker on the wrist and leave the phone at home. Maybe the new charge 5 has fixed this .. hopefully.
11-16-2022 06:57 - edited 11-16-2022 07:01
I have been having the same issues with my Sense GPS, I walk with my husband and he has the Sense watch to, he has had no problems with his watch so I know its my watch. I have found that if you have screen on top all the time setting on while I do my walk it stopped the GPS loosing its signal, I turned it on while I did my walk and then turn it off after. I hope this helps
