11-02-2019
13:20
10:40
11-02-2019
13:20
10:40
I've been using my Charge 3 for months, and I have an account on fitbit.com that I set up a while ago, but never really looked at until today. On my dashboard it says "no devices paired". My dashboard shows I've burned some calories, but I think that's just calories people burn for being alive.
How do I get my stats to pair with this webpage? I'd like to try to download some of my numbers if that's even possible. But I need to get my account on fitbit.com and my Fitbit that I wear on my wrist are both mine and connected.
Thanks
11-03-2019 05:03
11-03-2019 05:03
It's great to see you around, @TWC-ACD-Beag.
If you are seeing the "No devices paired" on your Dashboard, that means that your tracker isn't paired. I recommend setting it up by following the instructions provided in the help article: How do I set up my Fitbit device?. Also, I suggest checking that you are entering to the correct Fitbit account.
Let me know the outcome. 🙂
11-03-2019 10:09
11-03-2019 10:09
08-15-2020 06:35
08-15-2020 06:35
I have noticed that this is an older thread and no response was given, but I just ran into the same issue. Has anyone found a solution?
03-16-2022 18:53
03-16-2022 18:53
I am here from March of 2022 and also looking for an answer to this question.
09-08-2022 09:57
09-08-2022 09:57
The same issue being reported here, i.e., a Fitbit device stopping being paired (infor via the web-browser, although the Fitbit app says things are OK), and indeed syncing to third party apps such as Strava is a problem for me which started about a week ago. I can trace it back to when I went for a sea-swim and wanted my Versa3 to record the activity, and then upload it to Strava. Ever since I have had to upload activities manually via a tcx file, which is a little tedious to say the least! I am hoping it isn't a fault with the Fitbit.
