replacement band for a Charge 2
Does anyone know if the replacement bands sold on Amazon for the Charge 2 actually work?  Fitbit only has the large size in black remaining and I already wear the small on the last notch.  I don't understand why replacement bands are so difficult to find.  The watch works fine.  I've had it less than 5 years and I've already replaced the band twice.
4 REPLIES 4
I have bought third-party bands from Amazon that I've been pleased with.  But there are a variety of brands and styles.  I suggest find one that you like in your size, then read the reviews.
Thank you!  I'll certainly read the reviews.  Have you found a replacement brand you like?  I saw at least 3 on. Amazon.
I have bought for other models but maybe not for Charge 2, but have not had problems with any.  Most are inexpensive enough you could probably end up buying a few for the Fitbit price, so not so terrible if you get one that doesn't suit you.
Thanks again.  I have noticed that they are fairly inexpensive, so maybe I'll order a couple from different vendors.
