02-03-2021 03:08
02-03-2021 03:08
why am i having so much problem with my charge 3 tracking stairs in the last two days it recorded 53 flights of stairs when in fact it was more like 5 which makes me question the accuracy of the steps as well
Best Answer02-04-2021 10:08
02-04-2021 10:08
I'll say I've had my fitbit charge 3 for a few years now, it rarely gets things exactly right. That said, unless I manually count my steps and log them by hand, I don't expect anything to be perfect.
The Charge 3 doesn't really have the sensors required to 100% track your steps or stairs or anything. I've had my HRM show 70-80, when an external SpO2/HRM sensor is showing closer to 140, my google fit and fitbit constantly disagree on steps, etc.
This isn't a flaw or issue with the charge 3, it's more in the design - there's only so much information the fitbit can derive from the sensors included. As I mentioned, the HRM can be wrong, the steps are based on your wrist movement, stairs are too, so there's a lot of data produced from a few sensors. It's a miracle they come as close as they do most of the time - which is a testament to fitbit's heritage and abilities.
Long story short: the tracker will be wrong, it will often be wrong, but it's probably pretty close most of the time - which is what people are looking for. Additionally, it takes time for the charge 3 (or any tracker) to adjust to the user wearing it, we all step differently, we all have a different pace and gate on our step, some may limp all the time, some may limp some of the time, your steps are frequently uneven, etc. Whether walking, or going up a flight of stairs, everything changes all the time, and with the limited amount of information the charge 3 has to go off of to determine those factors, it may take a while for it to adjust to your way of doing things, and give you more accurate output.
As fitbit packs more and more sensors into their devices, things will get more and more accurate over time.
But hey, congrats on the lighthouse achievement.
Best Answer02-06-2021 04:09
02-06-2021 04:09
THANKS FOR THE REPLY AND I DO UNDERSTAND HOW NOTHING IS ACCURATE ALL THE TIME BUT BEING OFF A LITTLE IS OK LIKE READING 15 FLIGHTS WHEN IN FACT YOU DID 8 BUT FOR THIS WEEK MON.-FRI. IT RECORDED 130 FLIGHTS TOTAL WHEN IN FACT IT WAS AROUND 18 TOTAL THAT IS MORE THAN A LITTLE OFF. IS THE CHARGE 4 BETTER OR JUST MORE OFF THE SAME. THANKS
