05-22-2019
03:58
11:08
05-22-2019
03:58
11:08
If I tap the light bulb, a line appears across it. A second tap makes the line go away. What is this for? Don't know anything about this icon so don't know if I want the line on or off.
05-22-2019 17:43
05-22-2019 17:43
When the light bulb is on (no line through it), Your fitbit screen will come on when you turn your wrist in front of your face, like when you look at your watch for the time. Ok?
05-22-2019 04:47
05-22-2019 04:47
I saw that icon briefly as well and left it alone not knowing what it was for, now I can’t get my screen on without tapping or pressing button and can not find the icon again:/ Where did you find it?
05-22-2019 12:31
05-22-2019 12:31
05-22-2019 17:43
05-22-2019 17:43
05-22-2019 17:44
05-22-2019 17:44
It enables the screen so that when your turn your wrist to look at the time, etc. It will come on.. Otherwise, you have to tap the screen twice to make it come on.
Best Answer06-11-2019 20:15
06-11-2019 20:15
I agree - it's all hit and miss. How can they not have a manual of some sort ?
01-01-2020 19:15
01-01-2020 19:15
You hold the button on the side of your screen down. It also tells you how much charge you have. I hope this helped
Best Answer01-01-2020 19:39
01-01-2020 19:39
Best Answer01-05-2020 00:03
01-05-2020 00:03
If you hold the button it will pop up with the battery life on the top and the light bulb on the bottom. If the light bulb doesn't have a slash through it that means that your Fitbit should turn on when twist your wrist towards you. If the light bulb does have a slash through it that means that you will have to press the button or the screen to turn it on
Best Answer01-16-2020 07:43
01-16-2020 07:43
I have Inspire HR and the light bulb picture is found under the battery indicator. And both of them are shown when you press the button on the left side of the screen.
