01-15-2016
23:54
20:15
01-15-2016
23:54
20:15
Recently, I now need to log in with every opening of the FitBit Appliction on my laptop. For years before, it remebered my user name and password. Now I must enter both every time.
01-16-2016 00:03
01-16-2016 00:03
Exactly the same problem started 2 days ago. It now tells me there is more than 1 Fitbit when I try to connect and I've made sure there isn't another one within 100m!
01-16-2016 00:36 - edited 01-17-2016 01:03
@jjpdx wrote:Recently, I now need to log in with every opening of the FitBit Appliction on my laptop. For years before, it remebered my user name and password. Now I must enter both every time.
why people didn't read the forum before creating a new message for an already noticed problem ?
01-17-2016 00:52
01-17-2016 00:52
@jjpdx Are we posting about Fitbit Connect or the web Fitbit.com on your browser. ?
@SunsetRunner @TGJ
01-17-2016 13:54
01-17-2016 13:54
web Fitbit.com on my browser
Best Answer01-17-2016 16:54
01-17-2016 16:54
@TGJ wrote:web Fitbit.com on my browser
@TGJ All I can do is offer some help. I have just had the Fitbit Connect auto update and nothing has changed, all of my browsers are set to auto logon
I'm using Windows 7 on two computers and Firefox is my primary browser. Because I have multiple Fitbit accounts I also use Chrome, Safari, Pale Moon, Opera, Sea Monkey, IE11 and Avant.
All of these auto logon so all I can suggest is clearing your browser cache.
Here is a link to the web on "How to clear most browsers"....
I trust this may help..
Best Answer01-17-2016 22:11
01-17-2016 22:11
I don't have the issue with the dashboard/browser. But after the last "Fitbit Connect" application upgrade (running on Windows 7), I noticed that when I sync it says "Searching for Tracker"... as it did before, but now I get "More than one tracker found". No other tracker is around. And it asked me to login every time now.
13:43
07:32
RobertoME
01-18-2016
13:43
07:32
RobertoME
I think I gave the wrong answer last time - it is the "Fitbit Connect" on my PC that gives me the issue - exactly the same as yours.
i.e.
* After the last "Fitbit Connect" application upgrade.
* I run Windows 7
* When I sync it says "Searching for Tracker"
* Now I get "More than one tracker found".
* No other tracker is around.
* It asked me to login every time now.
Trevor John
Moderator Edit: Personal Information
Best Answer01-18-2016 14:15
01-18-2016 14:15
Same error here just started a few days ago. I called customer support and the person on the other end of the line hadn't heard of this error before. It seems like she should have been notified that this is a known issue.
14:48
07:42
AndreaFitbit
01-18-2016
14:48
07:42
AndreaFitbit
Exactly- it says "More than 1 tracker found". No other trackers around!!
John Jordan
Moderator edit: removed personal information.
Best Answer01-18-2016 14:50
01-18-2016 14:50
Exactly! More than 1 tracker found.
Best Answer06-02-2019 21:37
06-02-2019 21:37
I have the same problem now, for 2 days. It is really annoying.
Best Answer11-18-2019 09:43
11-18-2019 09:43
Same here since about 2 days ago. I'm on a MacBook Pro running the latest OS. Very frustrating!!!
